Home > Wheels & Tyres > Dynamic Balancing Beads - Mach 5s
Page 4 of 6 <123456>
SailingTom
Im going to be giving this company a call to see what they recommend for my tyre size as its not listed. Anyone used them for theres?
http://www.dynabeads.co.uk/dynabeads_4x4.php
Wont be using the wheels quite yet anyway but the weights are in strips on the floor where they have fallen off
Smile
My tyre fitters said they'll fit them and there a good lot, but as they haven't tried them obviously cant recommend them. Defender puma dormobile camper
Post #366849 24th Oct 2014 12:25pm
K9F
Think you'll find Devon are marginally cheaper. However when I did call the company in your link I found them extremely helpful and amaible. I will probably use them myself when ready to fit. The feedback section was quite informative too.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #366854 24th Oct 2014 1:13pm
Lorryman100
I opted for the dynabeads for my newly powder coated pro comp alloys with 305's fitted. They came delivered in their own bags with full instructions on how to use them but were not the cheapest option, 5 x 8 oz bags at �15.92 per bag. I went for the 4x4 dynabeads which need the tyre bead broken to place in the tyre as the beads are to large for the tyre valve. So far no issues with them and as the pro comps were a nightmare to get balanced this was an easy fix.
I have put a set of boosts in for powder coating in graphite, which are booted with 265's and I will use the dynabeads for them as well mainly because the clip on weights damage the paintwork of the wheel and stick on weights seem not to be very sticky these days.
Post #367569 27th Oct 2014 7:37pm
munch90
Everyone still happy with the beads ?
Post #392243 24th Jan 2015 11:57pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
^^^ Not me Crying or Very sad
I had the beads removed and all 5 wheels rebalanced, I've got Zu's with Duratrac 265/75/16's.
It's much better now they're balance properly, two of the wheels needed about 120g of lead weights, much to the surprise of the fitter, the other 3 were about 50/60g, after being rebalanced they are certainly smoother with no shaking at all. After I was satisfied everything was all good, I then had the tracking done, which has also helped.
Much happier now Smile
Post #392313 25th Jan 2015 11:01am
K9F
Lambley wrote:
Well, I've fitted some beads, 150g bag to each wheel and so far they are very good, no problems to report, seem balanced at all speeds.
Interesting. Thumbs Up
Did your fitter not consider rotating the tyre on the rim to reduce weight required? No expert but I know if the fitter has the time and inclination a lot can be achieved apparently.
What changed after fitting and your initial feedback? I haven't got round yet to going down this route but still intend doing so. Did you have enough beads fitted as the recommended amount for your tyre size is 177.5 grammes? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #392315 25th Jan 2015 11:10am
munch90
thanks for reply
interesting you gave up on them
im thinking of change my wheels , but my wheels now are balanced spot on , fancy changing the wheels and you weightless with beads
im not so sure now !
anyone else ?
Post #392316 25th Jan 2015 11:10am
Wheel
Interesting topic chaps,
I recently bought some 18" Overfinch alloys fitted with 265/65 BFG's from Urban Trucks (thanks Lee) and considered balancing beads and spoke to Dynabeads and very helpful but yes, quite expensive.
I haven't bought them yet as I've only had the new wheels on briefly, and they're off again due to a "discussion" at Lookers LR Chelmsford who wouldn't look at my tracking on a week + 2 day old 90 as I didn't have std wheels on.
Anyway, in a previous life I worked as a Toolmaker in Fords wheel plant where we made wheels for Transits which were only 14" as opposed to the 15" + 16" they are now.
I was in the area which made the "spider" (wheel centre) and they were checked for balance as part of the process and adjusted accordingly so when the spider was fitted to the rim the wheel would be good to begin with.
I recall it was said that if the wheel/tyre was out of balance below or above 60mph (can't remember which) it was the tyre as the process for making tyres was harder to control.
I don't know if this is still the case though as I would think manufacturing processes would have improved but that's probably why remoulds are generally harder to balance as are bigger dia tyres, possibly something to do with the density/thickness of rubber at certain points ??
Post #392335 25th Jan 2015 12:22pm
Lambley
I had bags of 150g which was the recommended for 265's, from Devon 4x4. I don't think that was enough to do a proper balance due to the style of tyres fitted, the Duratracs are quite a knobbly and rugged profile. They seemed to work when first fitted, I've only used them for maybe 3/4000 miles, I do a 5 wheel rotation every 3000 miles and I think that might have had something to do with it, after the last rotation it seemed worse, maybe the wheels that needed more balancing ended up on the front. I did stop and give each wheel a kick now and then to move the beads about to rebalance but they never seemed quite right. I'm sure they'd be fine with less rugged profile. I'm glad I tried them though.
Post #392350 25th Jan 2015 12:53pm
K9F
Maybe there just wasn't enough? I am using the Dynabead recommended weight chart, for your size you were an ounce short? For the size of tyre I intend using/fitting it's 225 grammes.
http://www.dynabeads.co.uk/dynabeads_4x4.php If you go through life with your head in the sand....all people will see is an ar5e!!
Post #392389 25th Jan 2015 3:05pm
Lorryman100
Yes and No.
Initially the beads worked flawlessly but once the temp started to drop I was getting mild wheel wobble between 55 -60 mph but once the tyres got warm the issue seemed to disappear. Then early one morning on the way into work I started braking and the wobble was horrendous, not sure what happened but the steering felt like neither wheel was balanced. Also if I raised the tyre pressures to 32 psi instead of 30 psi there was no wobble present even in the cold but a raise of 2 psi on 305's is the difference between a comfortable ride and a hard one. So I ordered another 8 oz bag of dynabeads and popped 2 oz extra into each tyre and have not had an issue with wobble. The dyna beads chart states that 8oz is required for 305/70x16 which is probably correct for a generic tyre but not a Mickey Thompson ATZ. Personally I would go up to the next weight quoted in the chart as the extra beads not required for balancing spread themselves out over the inside of the tyre wall. JMTW Thumbs Up
Post #392589 25th Jan 2015 10:30pm
I just balance them the old school way Thumbs Up
Post #392591 25th Jan 2015 10:45pm
K9F
Finally decided 9 months after my initial post that I am bored waiting for my Coopers to expire so ordered some BFGs, will get the refurbed Mach 5s out next week and give these a whirl that arrived yesterday. Mixed reviews on here of late but think it may be the differing chart weights between suppliers and/or too much bead lubricant application on tyre fitting perhaps? Interestingly I have gone for the same size tyres as Lorryman above but not as aggressive. Be good not to have any 'stickies' on the rim if they work.
Post #407304 13th Mar 2015 5:21pm
Landy-Novice
if i understand this right, to use balance beads, should you put tire on balancing machine to find out who many of the beads you'll need as too many will then cause the tire to be over weighed which will cause imbalance? and also they tires need to be clouted every so ofter so dislodge the beads from the inside of the tire structure so they keep balancing?
i run bfg 265' on freestyle's without any balancing without any issues. Thumbs Up
Post #407742 15th Mar 2015 1:50pm
KF your welcome to come over to my workshop and we can spinn them up on the balancers
As the workshop is non commercial we can spend as much time as you like to get it right Thumbs Up
Post #407752 15th Mar 2015 2:40pm
