Home > Puma (Tdci) > 2.4 engine failure
Mack
2008 Defender 130 Puma 2.4 HCPU Chawton White
2.4 engine failure
Hello all
I have been experiencing engine malfunctioning, injection related I believe. Randomly while in idle, revs go up and down from the 750 idle rpm up to 1000rpm. Sometimes, revs go so low the engine shuts down. When it shuts down, I re-start it, starts normally until the problem re appears (can be a few minutes or the next day). When on the road, the enigne sort of "hesitates" and gets normal again only if I go full throttle for a few seconds. Whenever these symptoms occur the injectors make strange sounds, announcing something is wrong.
10k km ago I changed serpentine and its pulley/tensor at the dealer. I will replace my fuel filter in a few days hope it helps.
I would really appreciate thoughts on this and/or experiences if any of you have had similar issues and how you got it sorted.
Thanks in advance
Mack
Post #392214 24th Jan 2015 9:24pm
Mack
Also between gear changes sometimes revs drop translating in powerloss and strange noise from the injectors
Post #392215 24th Jan 2015 9:30pm
RED-DOT
Try it with the fuel filler cap loosened? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #392292 25th Jan 2015 10:17am
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
I had exactly that problem last year, Stratstone Doncaster fixed it on the 2nd attempt. You could ring them and ask to speak Craig in service and say I sent you.
Post #392614 25th Jan 2015 11:44pm
Could well be the infamous Volume Control Valve on the fuel pump.
Post #392619 25th Jan 2015 11:54pm
Mack
Hi Red Dot thanks for your reply I gave it a try but its still the same.
Shaun thanks mate, the problem is Im overseas so... How did he fix it what was the problem?
Blackwolf thanks alot my friend your posts are always very helpful. So in case that is the problem, where can I get this volume control valve? If you know of a website I can buy it from so I can get it shipped to Panama. I havent had much luck trying to import spares as a retail so I am constantly buying at the dealers and this Defender is just becoming unsustainable every time at the dealer its atleast $500 for anything. I get new small insignificant issues almost every month that in the uk would be less than 60 pounds (or $100) but here I get ripped off constantly between november and today I have spent more than $4k in simple things but since its my only option I have to cope. If this keeps going like this Im going to have to put it away and use a jap truck. I find the truck reliable and useful the problem is the local cost of parts
Mack
Post #392730 26th Jan 2015 5:27pm
shaun.mobile
Mack
I have emailed the dealer asking them to let me know how they resolved the issue with my vehicle.
will post back when they come back to me.
Post #392912 27th Jan 2015 9:01am
The VCV should be available from any Ford or Landrover dealer, and they are often now to be found on Ebay. The Landrover part number is LR009837, and the Ford part numberis 1 514 885 (engineering part number 6C1Q 9358 AB). the part typicallly costs around £130 to £140 in the UK.
Remember that you will need to carry out a pump recalibration operation with a diagnostic tools afterwards and not all tools can do this (Nanocom for example can't).
The VCV is also sometimes described by other names, eg Suction Control Valve, so finding one on Ebay can be tricky!
Post #392917 27th Jan 2015 9:19am
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Available for £60 here, looks to be genuine...
http://www.ebay.co.uk/itm/BRAND-NEW-GENUIN...4ad7cab3fd
Post #393019 27th Jan 2015 4:26pm
That's a good price! Thumbs Up
Tempting to get one as a spare, they really aren't very durable. The Ford parts department told me that they are one of the "fastest moving items".
Post #393031 27th Jan 2015 5:42pm
landy andy
Exactly the thoughts I was having about getting a spare. Thumbs Up
Andy
Post #393039 27th Jan 2015 6:12pm
Mack
shaun.mobile wrote:
Mack
Thanks Shaun I really appreciate it
Mack
Post #393071 27th Jan 2015 8:13pm
Mack
Thank you Blackwolf I will get this done after I get the part. Only the dealer has the diagnostic equipment for the calibration so after I replace it to the dealer it will be. The engine got better since yesterday I emptied the water from the fuel filter. It was mainly water so when it stopped coming out the filter was empty so air got in. After bleeding the system with an air compressor it works better. Revs are not completely stable yet, but it improved considerably. I will order the part online and when it gets here I will replace it.
Mack
Post #393073 27th Jan 2015 8:19pm
Mack
Great price Phoenix thanks for forwarding the link! Thumbs Up
Mack
Post #393076 27th Jan 2015 8:21pm
Interesting. When I was suffering similar problems to yours (see the thread I started "contaminated fuel") I spoke to someone I know who is very helpful and the senior vehicle tech at a main dealer. He told me that whenever they have a 2.4 Defender in with any water contamination of the fuel, they now change the VCV as a matter of routine, since it is invariably damaged by the water. The same is the case if dirty fuel has made it past the filter.
It was very evident from him that the VCV is fragile in this respect. I bought my replacement from a Ford main dealer for convenience, and the parts manager said they sell loads, he said it was the fastest moving engine part.
Post #393080 27th Jan 2015 8:29pm
