Home > Puma (Tdci) > 7000 miles - air filter
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Changed my engine oil at 6000 miles on the clock using Millers xf C1, the oil drained was black as you would expect from a diesel engine
But I was surprised at the air filter which I just changed today at 7000 miles - and LR dont even change it at 12,000 miles Shocked and as I have found in the past are too lazy to check the filter if it is not on the schedule to be replaced.
New Mann C25122 fitted and i'm sure the engine will be happy Very Happy
Post #392139 24th Jan 2015 6:22pm
Caterham
good stuff !
is that a couple of red anodised valves in the back ground - presume you also have a gas flowed head to accommodate them?
and on a serious note I like to change oil and filters every 6000 miles - easy job, relatively cheap parts yet critical to the running.
Post #392154 24th Jan 2015 6:48pm
shaggydog
Bit big for a defender I think there wine glass bottoms!
Looks like your engine will thank you for the new filter, old one looked a bit clogged Shocked Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #392157 24th Jan 2015 6:51pm
Iktank
Caterham wrote:
good stuff !
Two critical easy items that keep vehicle running right
Nothing as technical as valves in the background, wine glass stems which will be filled with red lubricant in a minute Thumbs Up
Cheers Very Happy
Post #392160 24th Jan 2015 6:58pm
Iktank
You were spot on with wine glasses - Cheers to you also
They are now filled and being consumed, dont get many glasses per bottle - think i'll have to start another consumption thread Laughing Very Happy
Post #392162 24th Jan 2015 7:00pm
CatherineF
Is the air filter easy to remove on a TDCI? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #392166 24th Jan 2015 7:20pm
Iktank
catherine
very easy to do - I unplugged the air flow cable, undid jubilee clip to flexible pie that goes from filter box to turbo and pulled off the pipe, then only 2 clips to undo that hold the air filter box lid on, take of the lid throw away old filter fit new and put all back together (approx 5 minutes)
Make sure new filter is pushed into the base compartment as per the one take out - it is a tight fit. If filter put in correct the lid refits easily.
Thumbs Up
Post #392170 24th Jan 2015 7:33pm
Caterham
cheers....
(I was only joking for those that may have thought I was being serious)....
and even I can second the air filter replacement is easy.....just double check the lid is indeed correctly fitted at the back under the wing top.
Thumbs Up
Post #392193 24th Jan 2015 8:40pm
munch90
Thats quite black for 7k miles
do you drive in heavy traffic ?
exhaust blow ? I know air is drawn in from outside , but worth checking
also the paper looks like it may have got wet at sometime
i never changed mine for 20k and it didnt look as dirty as that
Post #392202 24th Jan 2015 8:57pm
Iktank
Munch90
I travel to from work each day which is 72 mile road trip comprising of approx 32 miles on the M4, 20 miles on the A465 and A4061,
When in work I do a minimum 10 miles per day on forestry tracks
So I would not say i'm in built up traffic but will get a lot of dirty spray getting sucked in and then there's the stone tracks - hence why I bought a LR RAI which should improve things (need to seal all the crappy LR pipe work to the airbox tho)
My Hilux also has a snorkel with the snout facing front and I have to change the air filter every 5,000 miles - going to turn the snout around which again will improve things for the air filter I stupidly a few years ago riveted the snout to stop it being stolen, waste of time having the snout forward as the truck does not go anywhere fast enough to have any improvements from RAM air (I had lot of motorbikes over 30 years and still have 2 now - you need good amount of speed to have ram air improve things eg ZZR1100 etc )
Post #392387 25th Jan 2015 2:58pm
Lord Sward
MannHummel air filters are what Land Rover use for factory fitting I've lead to believe. I use them on my TD5.
Post #392605 25th Jan 2015 11:32pm
shaggydog
Embarassed Appologies Caterham Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #392698 26th Jan 2015 2:09pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
heres mine at 12000 miles over 15 months; never seen one so black.
 1953 80"
1987 mini city e
2011 90"
Post #400984 21st Feb 2015 9:58pm
Here's mine at 10,000 miles. I was more concerned that the lower fibre element was detached over a quarter of its length:
Post #419470 27th Apr 2015 4:33pm
Just make sure you locate the two hooks on the far left here:
into the receivers in the lower box:
tucked under the wing.
Post #419475 27th Apr 2015 4:46pm
