Home > Puma (Tdci) > Draper Diesel Hand Primer???
x-isle
Apart from probably needing a longer pipe, does anyone know if this is a fit for the Puma?
I'm led to believe that the inlet is 10mm. Just wondering if the engine side QR connector is the right size?
I know that if you fill and fit, then usually a Filter change is ok, but at that price, silly not to if it works.
http://www.drapertools.com/product/43986/E...ing%20Pump Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #388487 14th Jan 2015 7:53pm
grumpy old git
No idea on whether or not is's any good for a Puma (as we haven't got one) but I've got a Draper transfer pump with the same middle section that I've used for filling axles, transfer boxes and gearboxes on both of ours for the past six years and it still works really well with no cracking or problems so that shouldn't be a issue.
Post #388500 14th Jan 2015 8:36pm
x-isle
Thumbs Up
As far as I know the 2 common sizes of QR lines are 13(ish)mm and 10(ish)mm. Pretty sure the Puma is the 10 ish. Craig Rogers
2007 Puma 110 XS
Post #388505 14th Jan 2015 8:40pm
x-isle
Seems as the Puma is 9.89mm.
In the end I decided for the Laser 5704 which is a 2 in one kit including equivalent to the Ford 310-110 (which is what the Puma uses) and the FL2 one which is 310-163
http://www.amazon.co.uk/Laser-5704-Diesel-...B00FZJKSB2 Craig Rogers
2007 Puma 110 XS
Post #388602 14th Jan 2015 11:37pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
I have one and had to use during the Xmas break. seemed to fit Ok and I squeezed a few times and nothing so I used a plastic lid
with a hole cut in and pushed a bit of air via fuel tank opening and fluid appeared straight away about six aie bubbles and 100ml diesel and it fired up
Post #388622 15th Jan 2015 1:46am
x-isle
Assume you are referring to the Draper one? If so, that is good news. Craig Rogers
2007 Puma 110 XS
Post #388637 15th Jan 2015 8:39am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi Sasha, just to be clear, are you saying you didn't use the primer pump but just put an air line onto the fuel tank?
Thanks. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #388771 15th Jan 2015 5:38pm
sasha2001
Sorry I was on holiday, I brought my here from memory as they are hard to get in New Zealand
http://www.ebay.com.au/itm/Draper-43986-Ex...27f30603fb
I connected it up to the fuel rail on the Puma engine using the male end, pumped a few times and got lazy and at the same time
my clever wife used a CD pushed over the fuel filler hole and pushed the air compressor hose into the hole in the CD , it leaked air a bit so used a flexible plastic lid off a vegetable container which seals up easy with a hole cut in it the size of the air nozzle, sealed like a dream fuel pumped out with 5-10 seconds through the Draper, a few bubbles and it was fixed, I was just being lazy and I had read of this technique on AULRO site. I am sure the pump would work ok as well, I extended the hose as the other end is too short to drain the fuel into a container
http://www.aulro.com/afvb/90-110-130-defen...ost2113791
http://www.aulro.com/afvb/90-110-130-defen...ool-5.html
Post #392046 24th Jan 2015 9:16am
Cupboard
Not done that on a Defender, but done that on a few things round the farm (and other people have been doing it for years before I was around) and it works well Thumbs Up We usually just put a rag round the filler to seal it.
It's really handy having tractors with on board air, just park the tractor next to whatever needs bleeding and away you go.
Post #392052 24th Jan 2015 10:20am
x-isle
As mentioned, in the end I got the Laser which is the same as the Ford 310-110A.
Made the job very easy. Didn't even fill the filter before fitting. Although found it was taking ages to pull the diesel through but after disconnecting the pump side of the tool for the first few pumps all was good. Craig Rogers
2007 Puma 110 XS
Post #392100 24th Jan 2015 4:18pm
Natlas
Thanks for the clarification Sasha. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #392227 24th Jan 2015 10:41pm
MartinK
Chaps - just wondered...
The LASER pump is ~£100
the DRAPER pump is ~£20...
Anyone used the DRAPER one???
https://www.drapertools.com/product/43986/...ing%20Pump
I'm about to swap my filter for the 1st time. Also about to go on a long road trip into mainland Europe, so may take the pump with me "just in case"... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #638006 17th Jul 2017 4:31pm
zsd-puma
I've got the draper one (it might be a sealey but it's identical)
I fitted to the end of the line from the tank, but it's a loose fit, so i wrapped some ptfe tape around the male end of the primer to get it to seal and just primed it into a bottle. That's enough to get it running.
Personally i'm tempted to buy some fuel lines from Land Rover and fit the primer in there permanently. It removes the chance of dirt ingress every time you disconnect it.
Post #638013 17th Jul 2017 4:48pm
MartinK
aha - the laser one (or OEM) fits here (borrowed pic):
Post #638016 17th Jul 2017 4:58pm
zsd-puma
That's right, but the draper one is a loose fit in the connector. I was going to buy that fuel line, and the short bit that goes to the pump for the connectors, then permanently plumb in a primer bulb like a lot of Diesels have as standard anyway (Peugeot XUD, Ford/PSA 1.4tdci etc)
Post #638144 18th Jul 2017 5:33am
