Home > Technical > Winching: theory vs real life
Page 3 of 3 <123
My bad, I should have expressed myself more clearly! Thumbs Up
Post #388818 15th Jan 2015 6:46pm
jst
the key bit was stalled, in which case its doubled as have a pulley block.
if pulling a load, the load is halved on the winch ropes with a pulley block (ign losses within block) but anchor point has sum of halves on stricken vehicle. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #388835 15th Jan 2015 8:02pm
blackwolf wrote:
If you really want some versatile pulling power, a Trewhella monkey winch or a Trewhella Wallaby winch will make even a 3500kg Tirfor look like a toy, but they're less suitable for 4x4 recovery.
Is that how they are supposed to be used Shocked
https://www.youtube.com/watch?v=81VyT87aK5Y
Post #388880 15th Jan 2015 9:54pm
It's certainly how they've been marketed for years, and yes, you can uproot trees up to a metre diameter or so with one. Shocked
I have heard that much of Africa's deforestation was done with Trewhella monkey winches!
The Wallaby is a slightly smaller and much more sophisticated version of the monkey winch (and also very scarce second-hand and expensive).
Post #388914 15th Jan 2015 11:11pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Theory vs real life
I have found it quite scary on occasion watching winching and also rope hauling through my work, seeing the ignorance about the potential to collapse a hauling system.
The question is, where is the weakest point in the system?
Is it the winches attachment point to the vehicle?
Is it the winch cable/rope (with a dyneema type rope then if its going over any sharp edge or abrading on itself then the answer is yes!)?
Is it your attachment point to your anchor point (have you maintained a rigging angle of less than 90 deg?)
Is the pulley up to the job or simply introducing more friction?
When teaching swiftwater rescue courses we do quite a lot of rope hauling to release trapped boats, casualties, vehicles etc and the key things that are forgotten (in my experience) are; Direction of Pull and Friction!
Conversely with winching how often do you see a vehicle being winched with a poor direction of pull, or simply being winched further into/onto the obstacle that has caused it to get stuck in the first place?
I have rarely had cause you use the winch on my 110 but would sooner extend out using strops and do a pair of twin line pulls (2:1) than a single line pull over a longer distance.
Chris
Post #391481 22nd Jan 2015 2:55pm
jst
i catn quote, but your last para does bring in more items that could fail into the equation but i understand the thought process Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #391566 22nd Jan 2015 8:22pm
Chris86
Quite true!
Its all about making an educated decision based on an understanding of the parts of the system. I base my comment on reducing the amount of 'work' the winch has to do, knowing everything else is within its limits!
Chris
Post #391601 22nd Jan 2015 9:37pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
In that regard, what should be the weakest point for it to fail safely? Winch motor?
Post #391804 23rd Jan 2015 2:48pm
Chris86
If the winch just 'stopped' then I suppose yes?
Elsewhere in the system it would depend on a number of things, the main one being cable or synthetic rope.
Synthetic ropes tend to dissipate their energy in a fairly controlled fashion (they are essentially a semi-static rope- low stretch) and weigh relatively little, wire cables stretch build up energy before breaking and are heavy! A few years ago I was stood nearby when an attachment to a pontoon with a tirfor attached under tension snapped- scared the S%1t out of me!
I have yet to see a shackle fail catastrophically, the ones I have seen fail have just been rendered unusable by being deformed (Ford county forestry tractor......)- however that isn't to say that they do not fail!
Probably the 'best' answer is anywhere where there isn't the potential for flying metal objects! Very Happy
Chris
Post #391814 23rd Jan 2015 3:05pm
Manage your failure mode by including a component which you know to be the weak link in a position where either failure doesn't matter, or the consequences can be contained.
Post #391840 23rd Jan 2015 4:22pm
Page 3 of 3 <123
