Home > Technical > TD5 and TDCi bodywork
IanT599
Hi all,
Just trying to workout some bodywork issues.
What panels are different on these two vehicles? Assuming both are 110 Hard Tops.
I know the bonnets are different and I believe the bulkhead is different.
Were there any other changes to the outside? If I started a build with a TDCi bulkhead would TD5 panels all bolt on?
Thanks Ian
2004 Discovery II TD5 ES Auto
1990 Range Rover Vogue Efi Auto (Future 100" Defender Puma)
2015 Compass Rallye 644
Sankey Mk3 Wide Track
Post #391038 21st Jan 2015 1:28pm
IanT599
Can anyone give me help on this? Ian
Post #394797 1st Feb 2015 1:29pm
Tiger
I believe you have it spot on
Bulkhead & bonnet are 2007 >
Everything else is the same as 2004 > (steel doors change)
Steering wheel spline and steering box changed and those 2 pin diffs
Oh and rear tubs for seats changed as did the rear seat x member on a 110
Post #394798 1st Feb 2015 1:34pm
gilarion
Yes you can, the doors although the inner frame is slightly different shape, dimensionally they are the same. There are slight changes to the rear tub but again that is only internally so it will bolt on with little problem.
Your only problem with a TDCi bulkhead is if you are going to fit a TDCi dash, will be the electrics and sensors for the gauges and speedo. Similarly it will also depend on what engine and gearbox you are going to fit?
Post #394801 1st Feb 2015 1:51pm
IanT599
I've heard about TDCi dash issues and not working correctly. Will have to see if there is a way around this and what it is that does't work properly.
It'll be the 3.9 v8 auto from a 1990 RRC with the Borg Warner transfer box. The speedo signal is electronic on my one as opposed to the older cable.
I'm after a 90 SW look just on 100" and with the 2 flip down seats. Ian
Post #394827 1st Feb 2015 3:02pm
bob neville
Hi Ian
One other thing with fitting a Tdci bulkhead is the bottom of the bulkhead interferes with a non Tdci gear lever so the levers have to be modified as well.
I was looking at fitting a Tdci bulkhead to my TD5 as you can find a lot of new Tdci BH's but new TD5 BH's are like hens teeth. Looking at what is involved I am not going to bother and I will continue my search for a new TD5 one.
Just seen your update so the gear lever issue does not apply !
2013 Defender 90 CSW - sold
Post #394843 1st Feb 2015 3:42pm
