![]() | Home > Technical > Indicator noise |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2239 ![]() ![]() ![]() |
You could find a largish noisy relay and wire up to the original flasher to make more noise. Alternatively you could wire a larger warning light or buzzer up.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Or you could sound-proof the entire vehicle...
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17814 ![]() ![]() ![]() |
Pop into a motorcycle dealer and pick up a buzzer as used on bikes. Work well on Series LRs and HGVs and other vehicles with high ambient noise.
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 ![]() ![]() ![]() |
Good idea guys,
Have a look at audicator ltd website
i fitted one on mine due to quiet led flasher unit and i had one left over when i sold a bike |
I think that a simple buzzer linked to the indicator relay will be the quickest cheapest option
And bl@@dy annoying i would guess if it buzz's all the time the flashers are going
Thats the point I'm afraid, I need it annoying so I can hear it
Velo-felo Member Since: 18 Sep 2014 Location: Forest of Dean Posts: 19 ![]() ![]() ![]() |
Had this on my TR6, found the relay hanging in mid air on the wires. Fixed it back to a metal tab on the bulkhead and it immediately made it 100% louder.
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I have a flasher relay/beeper on my motorbike so that I can hear the indicators as it's not a good idea to carry on indicating after you've turned on a bike !
Don't know if the relay would fit a defender though. I bought it from a website for a company called OOracing 2005 Td5 90 XS Steve |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6188 ![]() ![]() ![]() |
Don't you have warning lights on your dash to show that they're flashing? a quick glance at them (at the same time as you check the water temp/oil pressure light/battery charge light... don't you????) would tell you if they're on or off.
Oh why didn't I just think about opening my eyes and looking at my dash silly me, Thanks mate
![]() Right I bought a 12 volt buzzer of Ebay will fit it soon, hope it's ok ![]() |
David-H. Member Since: 20 Jul 2014 Location: Edinburgh Posts: 31 ![]() ![]() ![]() |
Hi all.
I recently had a little work done on my Defender by an auto electrician. Afterwards I noticed that my indicators were noticeable louder, but everything in the fuse box looked normal. A bit of poking about showed that the indicator relay had shifted up a bit and was resting against the upper edge of the fuse box, which was amplifying the clicking into the dash. Reseated the relay, and sound back to normal. David. |
