Home > Puma (Tdci) > Drivers window
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Drivers window
Hi all,
Drivers side electric window stopped working. Worked intermittently for a while if I gently wiggled the wires in the boot between door and pillar so Fairly sure it's a broken wire but have looked at connectors in the block hidden inside the pillar and pulled back most of the boot but with no visible breaks anywhere.
Next step is door card off and boot fully off to have a look unless anyone else has any bright ideas?
(Fuse is ok)
Cheers!
Post #390872 21st Jan 2015 8:48am
landy andy
The wires will be broken inside its insulation, inside the boot. You will need to play with wires or give them a real good pull, to find which one is broken. Very very common. I always extend wires when repairing and put new joints in post and other in door, so the new joints aren't going to be flexed.
Andy.
Post #390874 21st Jan 2015 8:52am
churchy
Thanks for speedy response! I guess my next question is then how do I determine which wire is for the drivers window?
Post #390875 21st Jan 2015 8:57am
K9F
Rustyboxx had an offside windows on his landy that didn't work, took us about an hour to fix. As stated door card off, tug on the cables entering the boot and carry out the repair before and after the boot by splicing in a new length. A cable rod would be handy to feed the new length through the boot and some good quality hermitically sealed splices. Three cables for the window from the motor red, blue and black all will become clear once the door card is off. Good luck.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #390877 21st Jan 2015 9:00am
landy andy
I don't even remove door card (due to clips always breaking), I just release the boot at each end and give the cables a good pull, or operate window whilst waggling one or other wire. The wires are the two thick ones. You can often see a dark section on the cables insulation where it's been arcing.
Andy
Post #390885 21st Jan 2015 9:26am
