Home > Puma (Tdci) > location of coolant temperature sensor?
bear100
fitting a new temperature sensor/sender due to mine not showing the correct temperatures, has anybody done this and can tell me the location of the said sensor? Embarassed
thanks
Thumbs Up Thumbs Up Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #390553 20th Jan 2015 3:44pm
TonoDef
France 2014 Defender 90 Puma 2.2 SW Santorini Black
Hello,
i believe it's Item 8 on this diagram ?
[/img]
Post #390624 20th Jan 2015 6:53pm
bear100
Hi thanks for the reply,
mine is a 2.4 and looks a different sensor, I've had a quick look in the dark this evening and believe its at the back of the engine in a right Censored of a place to get to, looks like bonnet off time! 2023 Defender L663 V8
Post #390636 20th Jan 2015 7:17pm
Lorryman100
The 2.4 does not have a dedicated coolant temp sensor. It does have a CHT (Cylinder Head Temp) sensor located at the rear of the engine and it is a bit awkward to replace. Thumbs Up
Post #390673 20th Jan 2015 8:05pm
bear100
That's the one lorryman! Looks a pig of a job too! 2023 Defender L663 V8
Post #390693 20th Jan 2015 8:25pm
Workshop manual states:
1. Remove the engine cover.
2. Disconnect the cylinder head temperature (CHT) sensor.
3. Release the CHT sensor wiring harness.
4. Using the special tool, remove the CHT sensor.
1. To install, reverse the removal procedure.
Tighten to 10 Nm (7 lb.ft).
Special tool is Socket, CHT Sensor 303-680 and just looks like a mulipoint socket with a cutaway down one side.
Post #390770 20th Jan 2015 10:02pm
bear100
Thanks! Obviously the cut out is for the cable, Iam hoping there's enough room for a open end spanner! Or il have to cut the wires and use a rachet spanner!
Post #390785 20th Jan 2015 10:23pm
Maybe a crows foot wrench would save you having to cut any wires or even a lambda sensor socket depending on what the actual size required is?
Post #390948 21st Jan 2015 11:22am
bear100
good idea!
its a 10mm or 12mm, ive got a 22mm lamda/oxgen sensor socket sods law it will be different size Evil or Very Mad
Post #390989 21st Jan 2015 12:56pm
munch90
Dont think it's anywhere near 22mm , while since i done one or looked at one , but think its about 16mm ( not 100% )
15mm Thumbs Up
Post #391164 21st Jan 2015 8:53pm
bear100
Spot on it a 15mm Thumbs Up 2023 Defender L663 V8
Post #391167 21st Jan 2015 8:58pm
bear100
Spot on its a 15mm Thumbs Up 2023 Defender L663 V8
Post #391168 21st Jan 2015 8:58pm
