Home > Maintenance & Modifications > Central locking conundrum
Page 2 of 2 <12
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
After some confusion -- I figured our central locking just wasn't working "sometimes" -- I found today that one of our doors just doesn't lock when we activate the central locking. It sounds like this is the same problem charliebaja had.
I'm going to take a look myself but just thought I'd ask beforehand -- is there any way I can temporarily disable the alarm if I'm going to be toggling the central locking on and off, probably with the door open half the time? I'm assuming I'll need to take the door card out to at least get a look at the mechanism.
(In passing, just found the central locking range improvement mod posted here as well ... might have a busy weekend coming up!). 2009 110 XS Station Wagon
Post #323730 14th Apr 2014 8:30pm
mk1collector
If just one door isn't locking it will probably be the wire from the post to the door that has snapped. It's a very common fault and reasonably easy to fix.
Post #323736 14th Apr 2014 8:58pm
Egghead
Both the rear doors on my 110 refuse to take part in the central locking Big Cry
From this thread I should:
1) Check the wire from door to post hasn't snapped
2) Lubricate the mechanisms - particularly the plastic spinney bits - with proper lock grease, not WD40, ACF50 or even GT85
So... the wire?
And... door card off = inevitable.
Two things that a picture would save a thousand words in explaining what I need to do and where I need to look.
Any graphic or video assistance very much appreciated. Bow down
Post #390216 19th Jan 2015 4:39pm
mk1collector
Almost definately the wire snapped in the rubber boot that goes from the b post to the door. If you take the card off the door and just pull each wire that goes into the rubber boot one will come out easily. Best to put a section of thin wall wire to the same spec right through the rubber boot rather than just re soldering or you will have to go back in after a year or so.
Post #390269 19th Jan 2015 6:58pm
bear100
My drivers door started today also, trouble is when the fob is pressed to open the door the lock button doesn't quite reach full unlock so the central locking shuts again!
Another job to the list Sad 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #390303 19th Jan 2015 8:03pm
Page 2 of 2 <12
