Home > Puma (Tdci) > 2.2 EGR cleaning cycle vs 2.4. should I hear same noise?
Page 1 of 3 123>
lohr500
Every time I stopped my 2.4 I could hear the egr valve going through it's cleaning cycle.
My 12 plate 2.2 doesn't seem to make any similar noise. Does this mean the valve is damaged or is the 2 2 set up different?
As far as I am aware the vehicle is standard spec. with no remap. No warning lights on the dashboard once engine is running.
Any advice much appreciated as ever. Thanks
Post #390110 19th Jan 2015 10:05am
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
I've got 2011 DC 110 and having read all the posts about cleaning cycles etc that pop up I've never heard mine either Embarassed It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #390114 19th Jan 2015 10:12am
schuee
I had a 90 2.2 last week as a courtesy vehicle, and no EGR cleaning cycle after turning off the engine, thought there was something wrong, then I'm sure on the 2.2 it's turned off by design?
Post #390194 19th Jan 2015 2:32pm
x-isle
That's interesting, anyone shed a light on why? It's not turned off in Ford-quise, or at least it cleans on my 2010 2.2 Transit. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #390195 19th Jan 2015 2:35pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
I heard mine after a while. It was replaced under warranty. If you know what to hear for, you can still hear it, but it must be very quiet. Mine's a 2.4 btw.
If you hear it, it may be dirty and the valve is running dry.
Post #390199 19th Jan 2015 2:49pm
x-isle
I replaced mine and heard it straight away in my 2.4, although it was a lot quieter as the old one was sticking and making very load noises, even when opening/closing when driving.
Funnily enough, this weekend, I had a stutter at around 2,000rpm when warm and didn't hear the clean on one of the shut downs, so suspect my current one is starting to clog up too. Although a pain, I'm not interested in removal/disable/block-off as it has it's purpose. Craig Rogers
2007 Puma 110 XS
Post #390200 19th Jan 2015 2:53pm
ericvv
Post #390211 19th Jan 2015 4:25pm
lohr500
Good question Eric.
If it doesn't have one that would indeed explain why I can't hear it. Embarassed
Post #390218 19th Jan 2015 4:43pm
Afaik Eric is correct.
Post #390221 19th Jan 2015 4:50pm
x-isle
I'm pretty certain the 2.2 has an EGR?
Wasn't Pete (Bell) the first to crack disabling it?
EDIT: Here's the post - http://www.defender2.net/forum/post211890.html Craig Rogers
2007 Puma 110 XS
Post #390222 19th Jan 2015 4:57pm
ericvv
Read on aulro.com that the 2.2 Puma has a new type of water cooled EGR valve... Maybe without the chuka, chuka, chuka cleaning cycle of the 2.4 ???
Also read that those too fail eventually, and would cost x times more than those in the 2.4....
Guess the jury remains out there until we get the wisdom from one of our tech experts. Bow down
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #390230 19th Jan 2015 5:24pm
x-isle
If it's the one I'm thinking of (that's fitted to later Transits), then it's exactly the same but just has a water pipe running across it to cool it.
I think that they are interchangeable too, although you'd have to tap into a coolant supply. Craig Rogers
2007 Puma 110 XS
Post #390235 19th Jan 2015 5:44pm
x-isle
This one
http://www.ebay.co.uk/itm/Ford-Transit-Mk7...4d110e8f6d Craig Rogers
2007 Puma 110 XS
Post #390236 19th Jan 2015 5:45pm
MikeJ
United Kingdom 2013 Defender 130 Puma 2.2 HCPU Fuji White
My 2.2 definitely has the chuka chuka noise, but it's not every time the engine's turned off.
Post #390435 20th Jan 2015 12:22am
Re: 2.2 EGR cleaning cycle vs 2.4. should I hear same noise?
I may be mistaken, but I don't think that the EGR cleaning cycle even on the 2.4 is supposed to be audible - a new valve should be just about silent in operation, then the chukka chukka sound indicates that the valve is getting ropey, then the reversion to silence indicates that it is stuck.
Mine was noisy but nice Mr Bell fixed that! Thumbs Up
Post #390481 20th Jan 2015 10:27am
Page 1 of 3 123>
