Home > Puma (Tdci) > Puma TDCi - no Diesel Smoke?
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Has anyone else noticed that their TDCi Engine does not seem to blow any diesel smoke, even under vigorous acceleration?
Post #38983 24th Aug 2010 11:20pm
CapeLandy
South Africa
Yep
Post #38985 25th Aug 2010 6:24am
Naks
indeed.
me thinks it all gets stuck in the cat Confused
Post #38990 25th Aug 2010 8:04am
dgardel
Italy
Because is an engine designed for 180CV and more..... (eg Ford Galaxy Germany version)....
So it can do a lot more....
Depends only from the electronics (and from piezo injectors [not simply solenoids like ours] installed on Galaxy).
p.s. our injectors are more strong vs bad diesel, piezo injectors have more trouble with low quality fuel.
My Defender with BAS remap doesn't smoke, NEVER, I tried at 2800m (Stelvio pass) and no smoke anymore
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #38994 25th Aug 2010 8:22am
dgardel
Italy
Naks wrote:
indeed.
no, cat isn't the DPF, if you have a "smoky" motor, cat or w/o cat the exhaust pipe show you the color of darkness.... Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #38995 25th Aug 2010 8:24am
CapeLandy
South Africa
As an aside - in South Africa we don't have catalysers. Well, I don't
If you read your chassis number, the 8'th letter is either an S or T
The s- is for the euro specked engine with catalyser and the T is for non catalysed
Post #38998 25th Aug 2010 9:03am
Naks
CapeLandy wrote:
As an aside - in South Africa we don't have catalysers. If you read your chassis number, the 8'th letter is either an S or T. The s- is for the euro specked engine with catalyser and the T is for non catalysed
Wow, didn't know that. Just checked, mine's also T. I wonder why ours don't have a cat? Bad quality diesel?
Post #38999 25th Aug 2010 9:10am
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Mine smokes a bit (2007) - e.g. at 5th gear, flat road, when I depress the accelerator pedal and press it again I can see a little of smoke. It does so from the beginning. Janusz
www.yahodeville.com
Post #39000 25th Aug 2010 9:15am
Grockle
I've not got a cat either just a rabbit(Thumper) 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #39008 25th Aug 2010 10:15am
dgardel
Italy
it is not the engine, is the EGR valve delay, may be you need to check it, is a common problem for the 2007 EGR valve type. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #39010 25th Aug 2010 10:31am
My 2007 Puma doesn't seem to smoke much (at least I haven't noticed it smoking) but the tailpipe is very sooty and black. Several others I have looked at in car parks also seems to be sooty. Is this normal?
Mind you my TD5 Discovery is also fairly sooty up the tailpipe, though not as much as the Defender.
Post #39011 25th Aug 2010 11:06am
dgardel
Italy
yes w/o DPF it is absolutely normal...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #39013 25th Aug 2010 11:19am
MK
Removal of the catalyst will affect the opacity gas exhaust? Puma 110" SW
Post #39014 25th Aug 2010 11:22am
dgardel
Italy
no Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #39015 25th Aug 2010 11:23am
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Sort of goes against the saying 'no smoke, no poke'!
Having said that the only time mine has ever given off any noticeable amount of smoke if after a few weeks of dawdling around town at low revs, then booting it onto the motorway there was a nice cloud of smoke visible in the rear view mirror. But thats the only time it's ever done it.
Post #39043 25th Aug 2010 5:39pm
