Home > Technical > Trailer Light flashing
CatherineF
I've noticed that when we indicate (left or right) the trailer light flashes at the same time as with the left or right indicator light on the dash.
Looking at the invoice for the last service I think the previous owner reported the problem to the dealer who couldn't find a fault.
Any suggestions as to what it might be as it should only flash when hooked up to a trailer. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #389187 16th Jan 2015 9:06pm
Only once or repeatedly?
Post #389189 16th Jan 2015 9:10pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
If it is once then it is normal. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #389195 16th Jan 2015 9:16pm
CatherineF
I think it might be once, will check in the morning when I take her out. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #389212 16th Jan 2015 9:42pm
It's normal then if just once, mine doesn't have it at all unless timing because I have the RDX relay.
Post #389217 16th Jan 2015 9:50pm
CatherineF
Are you Dynamatting this weekend Steve? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #389221 16th Jan 2015 9:52pm
Highly doubt it, loads to do...
My 90's getting a little neglected at the moment but I'll catch up soon. Laughing (I think)
Post #389258 16th Jan 2015 11:25pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
My Tdci 2.2 does this too, just the one flash, I believe this is normal 1970 Series 2A 88"
Post #389269 17th Jan 2015 12:30am
CatherineF
OK been out this morning in it and it flashes all the time. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #389323 17th Jan 2015 11:16am
Rickydodah
Mine too Confused I started with nothing and still have most of it left!
Post #389328 17th Jan 2015 11:24am
Happyoldgit
Next question is does the vehicle have standard filament bulbs or LED's in the indicators? Steve.
http://forums.lr4x4.com
Post #389334 17th Jan 2015 12:04pm
CatherineF
All the lights have been upgraded to LED"s 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #389337 17th Jan 2015 12:15pm
K9F
That'll be why then. Do you have an adjustable RDX relay fitted?
Do a search if you need more details.... Thumbs Up
smb wrote:
Yes, I purchased it as a whole kit from BoltonBits, but the full kit doesn't come with the side repeaters so I just left the originals in. I replaced the standard relay with the RDX one and turned the knob until the trailer warning light just went out.
I would say the flash rate is slightly faster than the standard. I have also tried it with both LED and Incandescent Light Boards on the trailer and no problem experienced, not even having to adjust the relay either.
The only problem I keep getting almost on a daily basis is because I went for an All Clear set, every time someone sees me reverse they come up and tell me I've only got one reversing light working. It's becoming a real PITA!!!
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #389338 17th Jan 2015 12:17pm
Happyoldgit
Thunder well and truly stolen Mal Wink Thumbs Up Steve.
Post #389339 17th Jan 2015 12:21pm
ChrisJ
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
I asked the same question when I first go my td5, I believe it's a bulb check.
http://www.defender2.net/forum/topic28822....iler+light
Post #389340 17th Jan 2015 12:23pm
