![]() | Home > Puma (Tdci) > Recall work & other work |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Wow - that does look bad...
| borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677
Mine goes in tomorrow to investigate an oil leak coming from the bell housing.
| Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439
Just had my 2013 USW in for water leaks Busboy and I had water dripping from the bulkhead seal too.
I was told it was actually coming down from the window seal which they replaced and so far so good. Good luck with getting that lot fixed though. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
| Busboy Member Since: 23 Jan 2012 Location: West London Posts: 182
Well the fun begins
Today the recall work was completed, great, and the body shop investigated the water ingress problems. With the car now being 3 1/2 years old and out of warranty they agreed to look at the windscreen leak as they had previously done some repairs in that area,and agreed to replace the door seals but the leak in the roof apparently is coming through the small skylight window rubbers maybe down to me to cost but they said they will try to see if Landrover will do a goodwill gesture The roof lining stain will be down to me to clean Well done Grange for your assistance, just need the body shop to do a decent job |
| Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320
Just had mine done of this and new clutch, it comes from the main crank seal |
| Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921
Sorry to drag a fairly old topic up, but I've now got oil coming from the bottom of the bell housing on my just under 15000 mile 2014 110 van. Assuming it is the rear crank seal, should I ask them to put in a complete new clutch (at my expense) while they're in there, whether it really needs it or not?
And is there anything else (greasing the shaft that gives out - I've never taken in which one it is?) Thanks folks. |
| All times are GMT |
