![]() | Home > Maintenance & Modifications > Dynamat fitting panel wipes |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Brake cleaner or petrol, when I did mine. May have also used a tub of body shop wipes until I ran out.
Andy |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
We use this in work..
http://www.arrowchem.com/engineering/lotoxane-fast-wipes/ If you were a bit closer, I'd give you a box! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Mike, how much is that? Is it available or trade only?
Wipes only would be better as I think 5ltr is rather a lot which the Upol is, then there is only two options to do with any surplus either sell or specialist waste disposal. I don't really want to be using anything with too much fumes from it if I can avoid it. I know my 90 isn't very dirty at all under the matting but it's best to be done anyway. |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
Pop to a spray shop and get some panel wipe off them. Its the best stuff you can use
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I sometimes use methylated spirit to clean things before applying anything adhesive. 2005 Td5 90 XS
Steve |
Drop me a PM. I'll see if I can grab a tub next time I'm in work. How much of a rush are you in?
