![]() | Home > Wheels & Tyres > Matt Lee Mach 5 steel wheel, Special Nuts ?? |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
You need steel wheel nuts. The boost alloy nuts won't work.
I used to buy sets direct from Matt raw and used to paint them myself, so some may be painted some people may have powder coated them.
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
as above, use the standard defender steel wheel nuts.
I had my set shotblast and powder coated recently and they came up like new. ![]() |
Windowlicker Member Since: 24 Aug 2014 Location: East yorks Posts: 290 ![]() ![]() ![]() |
Thanks for the the replies chaps
![]() Does anyone do stainless or stainless jacketed ones, as per discovery wheelnuts, I just can't see painted steel one lasting too well. Relative to poweder coating the steel ones, does it not increase the external diameter to the extent you have issues getting a socket onto them? Thanks. Nick. "Procrastination is the thief of time" |
Well I have just found some stainless steel nuts on the bay, they appear to be a taper seat face , are the Mach 5's flat or taper seat?
The pics I have seen of them ( poor ones granted ) appear to show them with a flat seat? Confused ![]() |
Tapered standard defender wheel nuts for steel wheels is what you need.
Thanks very much Greeni
![]() The listing was for Defender/disco1 steel wheel nuts ( in stainless ) "Procrastination is the thief of time" |
I'd put a picture up, but I can't drive this iPad. But yup, they're them.
Alloy wheels have a different chamfer on the nuts than steel as explained. Wrington can supply all your needs. Mach 5 wheels were supplied either powder coated or untreated allowing the purchaser to get them finished as they wished. I have two sets and both were powder coat finish.
http://www.wrington.co.uk/index.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks K9F,
How mucking futch are those nuts ![]() ![]() What are people's oughts on these ...... http://www.ebay.co.uk/itm/LANDROVER-DEFEND...58bca8dba1 Thanks, Nick. Edited to say , I have just looked at the CORRECT section ![]() ![]() Last edited by Windowlicker on 14th Jan 2015 10:02pm. Edited 1 time in total |
They're a bit posh, I'd be happy with a set of standards!! I have some steel locking wheel nuts, but they're going on my wolf steelies when the 90 is built.
I know what you mean Greeni, but I can't stand scabby nuts
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Matt at FCX supplies SS wheel nuts too
![]() http://www.fcx.co.uk/#!product/prd1/262123...-wheelnuts Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Hi john.
Thanks for the heads up , I wasn't aware fcx did those. Cheers ![]() Nick. "Procrastination is the thief of time" |
