![]() | Home > Td5 > 31 mpg |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Long steady motorway driving gives better fuel economy than stop start and shorter journeys
| Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3802
Mk1, With ALL my other cars, I've found what you have said to be true, but I've found the opposite to be the case with our Puma 90.
We have some big distances in Aus, but I've found that I get better MPG around the city than in the country. I was told that sitting on 100/110kph in a Defender takes a lot of "ooomph" to push it through the air, hense better economy in the suburbs at around 60kph? Pickles. |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
Interestingly my 110 is much better on fuel cruising at 75-80mph than at 60-65
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
I've had 37mpg in my Td5 on a run, but I don't push it. The consumption seems to drop off a cliff on mine at anything over 70mph so I try and stick at between 55-65 like most lorries.
Around town and general driving is 34mpg. I got improved mpg after a tune and better still with 1.2 gearing in the transfer box. |
| Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 436
untill i put my roof rack on, i could get over 30 mpg, thats with a tuned engine and disco cogs in the tranny box. Also that was cruising between 60 and 70. Now with the roof rack, im only getting 26/27 and nearer 20 if i gas it or tow.
I am suprised with yours if your only travelling around 50, mud terrains do make a difference but i wouldn't have though that much..... |
I also use Ecomax after a flll up, that is probably helping, plus every 4/5th fill up I put 200ml of 2 stroke in.
Interesting as I always had to stick at 55 to 65 like lambley or my mpg dropped like a stone but I've had a disco t box fitted now so I'll see what it's like when I go to pick relatives up from Exeter in a couple of weeks. |
Try at 90 to 100 kph and I bet it's a lot better |
| 110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153
Mine does about 26 used as a weekend car. It's currently at the garage though. With a multitude of faults. God knows how much it'll cost. Still no problems for 8 months which isn't a bad run for a 14 year old 100k+ car I suppose. 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
With my Camel Discovery I managed 39mpg 14 km/ltr once. When driving through f France from Lyon to Luxembourg in more or less one go only stop at the toll gates. But I was driving between 80 and 90 km/hr as I was following friends who had there toys on trailers.
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
Lambley
Can I ask who did your tune please ? |
Yes, Gary at Alive did it, well worth the trip. I've been to see him twice now, once for the initial tune and again for a health check/tweak if you like to make sure everything was as it should be. On the second visit I asked him to 'flatten it out' a bit in the low range to stop the sudden surge of power, which he duly obliged. 10/10
| Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169
In my td5 auto 90 with full roll cage I was getting about 24 average in the UK commuting to work, mix of urban roads and A roads.
In Australia, this improved to about 26.5 mpg, fully loaded with winch, roof tent, loads of heavy spars, camping gear, fridge, etc. Best mpg was about 31 doing a steady 60 for several hundred KMs, worst was crossing the Simpson Desert (1200 sand dunes!) at about 19mpg. It is defo steady cruising that helps Td5 mpg, whereas mixed speeds and traffic do it no good at all. Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
| WorcsTD5 Member Since: 01 Feb 2014 Location: Worcester Posts: 23
Hi, I've just started a new contract (at JLR in Solihull, actually I brim the tank and calculate the mpg from miles driven vs litres of diesel. On the last run my maths told me that I was getting 32.5 mpg. I'm looking to improve on this... any ideas? |
| All times are GMT |
