Home > In Car Electronics > Help Needed 200Tdi 110 Rear Wireing Diagram Wire Misbehaving
shaggydog
[img]Hi Guys,
Can someone please point me in the direction of (or offer assistance) to track down what the rear wiring in my 110 all does?
I need an ignition live and the one I have plugged into (unused green female bullet) seems to go off after about 5 seconds which is not what I want.
What color wire am I looking for?
How can I find out what wire I have plugged into?
Thanks in advance Thumbs Up[/img] Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #388035 13th Jan 2015 2:41pm
shaggydog
Have found this but doesn't seem to show the wire I have plugged into Shocked
Post #388042 13th Jan 2015 3:03pm
shaggydog
Can anybody shed some light on this?
I can't figure out what's happening here.
I have plugged into a Female connector that has both Green and Green Brown wires coming out the other side which SHOULD indicate that its a ignition live.
However when I turn the ignition on it powers up for a short period of time then turns off.
What am I doing wrong? is it just the wrong wire or am I missing something? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #389432 17th Jan 2015 5:21pm
PaulMc
The Green/Brown wire is from the reversing lights circuit.
Have you got a picture of the connector that you're plugging-in to Question
The circuit diagram you've posted, is a 'coloured-up' copy of the diagram from the workshop manual for vehicles up to the end of the 1990 Model Year (end of the 2.5DT engine).
There was supplementary information issued for the introduction of the 200Tdi engined vehicles, starting in the 1991 Model Year (I don't have this Sad )
This diagram covers the 200Tdi models (I think that it's from the Haynes Book of Lies) -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #389442 17th Jan 2015 5:49pm
shaggydog
Reversing light loom may make sense though its the wrong side?
Cue rubbish photo Big Cry
Post #389458 17th Jan 2015 6:16pm
PaulMc
On a vehicle of that age, all the wires in the chassis harness come through the wheelbox into the vehicle, behind the RH rear lamp cover, and are terminated in bullets in snap connectors.
There's a sub-harness that connects into the bullet snap connectors, which goes down back out of the wheelbox, across the back of the vehicle, and up through the LH wheelbox, behind the LH rear lamp cover, for all of the N/S rear lights.
Reversing lights and rear fog lamp connections are available at both sides of the rear of the vehicle - which makes 'doubling-up' the reversing and fog lamps very easy.
If both the Green/Brown and Green wires are coming out of the same snap connector - then, they're both on the reversing lights circuit.
The 4-way snap connectors, like this -
are all one circuit.
. Paul.
Post #389467 17th Jan 2015 6:37pm
shaggydog
Thanks for that Paul Thumbs Up
So, if I cut the green wire out of the connector would that work or is the green wire just connected to the reversing light switch? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #389474 17th Jan 2015 6:53pm
PaulMc
So, are the Green and Green/Brown wires coming from the same snap connector (I couldn't really make it out from the picture) Question
. Paul.
Post #389506 17th Jan 2015 8:10pm
shaggydog
Yes they are, will go and take a better photo Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #389720 18th Jan 2015 12:16pm
shaggydog
Well, I'm a dumbass Banging Head
Despite looking once, twice, three times i have plugged it into the reversing light circuit as both wires are green brown.
Lesson learned: don't do wiring projects in the dark after work!
Still searching for a solid green wire and I have found this one in this connector, can I use it or is it a trigger wire (ie not always on when ignition on?)
Thanks for your help Paul Very Happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #389725 18th Jan 2015 12:31pm
PaulMc
They are both the same colour - that makes sense Thumbs Up
The way these bullet/snap connections are done, is that - one wire is the incoming feed, the other(s) are out to the lamps.
The solid Green wire in the 4-way connector, is the ignition-switched live for the rear wiper motor.
As long as you aren't adding a heavy load to it, you should be OK to use it.
. Paul.
Post #389797 18th Jan 2015 3:04pm
shaggydog
Thank you for the confirmation Thumbs Up
Its not a high load at all, only a signal wire so shouldn't notice it.
I never use the rear wiper anyway so should run little risk of overloading the system.
Thank you for your help, very much appreciated Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #389803 18th Jan 2015 3:19pm
K9F
You could always put a small 20mm in-line fuse in your tap off to make sure you don't ever lose the wipers. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #389806 18th Jan 2015 3:23pm
