Home > Puma (Tdci) > Tdci won't start
Shepherd
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Tdci won't start
Hi all
I have a 2008 county hardtop.
The engine will crank for a couple of seconds then it dies. The engine then won't crank at all till I lock and unlock it again.
I have replaced the battery in the key fob and tried the spare keys. It still does the same thing.
I have given the plugs a wiggle on the green box behind the dash and given all the relays under the seat a wiggle.
I don't have the EKA code in the manual so unfortunately can't try that.
I have a feeling its the immobiliser thats causing the problem.
Any suggestions?
Much appreciated
Post #387863 12th Jan 2015 10:52pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I've have exactly that problem with my 2008 110 since I bought it a year or so ago. I have also tried changing batteries etc. I think that it a fault with the passive immobiliser. I haven't bothered looking into getting it fixed but just got used to occasionally having to lock and unlock. .. Sorry, not much help, but you're not alone. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #387871 12th Jan 2015 11:05pm
Mogboy
Australia 2007 Defender 110 Puma 2.4 SW Belize Green
I had what sounds like the same problem a few years ago in my 2007 Puma. It was the engine immobilizer, which the dealers had great difficulty fixing properly. I asked them to deactivate the immobilizer feature completely as I didn't want it happening again especially in the desert or remote areas.
Post #387932 13th Jan 2015 2:29am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Hi,
I know you have said about the relays under the seat, but try them again.
I had this last week, left for work it started fine got to local fuel station put fuel in got back in, went to start.......click nothing!
Tried 3 or 4 times sounded like starter had jammed.
Pulled relays under seat and tweaked the pins tried again and away it went to my relief!
Ian 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #387944 13th Jan 2015 7:56am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
I did have the same one month ago at my work.
As you, no EKA code !
After some 10 try, it start again ...
I have send a email to my dealer, no answer.
I suppose that the immobilizer was confused with some radio frequency
Of course, I will not be happy if I have again the problem certainly if far from home !
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #387991 13th Jan 2015 12:15pm
I would suggest removing the main ignition and starter relays from under the seat and making sure that the contacts are good and tight. A loose contact on one or more pins is a very common problem. Generally a slight bend in the tang of the contact will tighten them up. It should be quite difficult to pull them out - feeling almost as though you're about to pull the socket off the bracket - and often they're sloppy as a sloppy thing.
If all is good, use a Nanocom or similar to to turn off the passive immobiliser and run for a while without it. Usually this will solve most starting issues. The vehicle is still immobilised if you lock it with the plip, it is just that we won't immobilise itself if you simply stop the engine and leave it (unlocked), so it is still inherently safe. If this does solve the problem, I suggest simply leaving passive immob off. No-one will know, and it doesn't really make the vehicle any easier to steal as long as you lockl it.
Passive immob seems to cause a lot of problems on Pumas (more so than on TD5s). It is known that there are likely to be problems if you have a second set of keys (or rather the plip, since this contains the transponder) within range of the exciter coil on the column, and the range can be as great as the rear of a 110 (if I have to carry a spare set of keys, I put them in an old-fashioned metal tobacco tin whcih acts as a Faraday cage). Also, if you leave the key in the vehicle with with ignition off, whether or not it is in the column switch, it can confuse the immobiliser.
Post #388041 13th Jan 2015 2:57pm
Caterham
I'm sure the above is where you should be looking but after ready my ' bible' on 'how to be perplexed' you might also want to verify the crankcase sensor is operational as this is key to the start sequence.
Post #388044 13th Jan 2015 3:08pm
Shepherd
Hi,
Thanks for all the replies so far, not had much time to look at it today but did tighten all the connectors up on the relays. They can be felt/heard clicking nicely when ignition is turned.
I also gave the crank position sensor connector a spray of contact cleaner and a wiggle.
Also took the steering wheel and plastics around the steering column off. Found the wires to the transceiver coil and gave all that a wiggle.
Only slight progress is I have found A mysterious wire. Is from the anti theft module (green box!) the left hand grey multi plug, the far left wire in this loom (Orange and grey) is just hanging there with wire stripped at the end!?
Trying to find a wIring diagram to see where this goes.
Will also get hold of something to try turning the passive immobiliser off.
Thanks again for help so far.
I will keep you all posted on the result
Matt
Post #388068 13th Jan 2015 6:06pm
The odd wire will be the aerial for the remote plip (lock/unlock function), and no, nobody knows why the end is stripped before you ask!
Post #388071 13th Jan 2015 6:24pm
Shepherd
Ok thank Blackwolf, that saves me some head scratching
Post #388075 13th Jan 2015 6:38pm
carrotbay
If you were to lengthen that wire would you get better range on the 'plip' ? 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #388459 14th Jan 2015 6:30pm
Rickydodah
If you were to lengthen that wire would you get better range on the plip?
Yes, I've run mine up the A post and under the headlining to the B post area. Reception much improved. Thumbs Up I started with nothing and still have most of it left!
Post #388508 14th Jan 2015 8:57pm
tcqf
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Had the same problem with mine,tried all the usual things in the end took the advice of blackhorse and bought a nanocom and turned off the passive alarm job done the best money I ve spent including the landrover
Post #401514 23rd Feb 2015 9:34pm
tcqf wrote:
...took the advice of blackhorse...
??? ! Shocked Rolling with laughter
Post #401522 23rd Feb 2015 9:58pm
Borderrover
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Santorini Black
Very Happy I had the same issue after having a service done recently.
Engine would only turn over 2 time then stop. Occasionally start then stop again. After some searching on the net I started looking for the green lucas 10as alarm / immobiliser unit. Various post said it is behind the tacho cluster. Not on the tdci. I eventually got access through the lower driver side speaker. The 2 torx screws were a pain to get to but I managed. My problem was a bad connection on the grey plug. I then ended up with the hazrds flashing. This went away when I closed the driver door and turned on the ignition. Since cleaning the connections there have been no more issues. Its a pretty poor design for something that basically makes the car unusable.
I also extended the arial cable at the same time and created another earth connection for thr green plug just in case this was at fault. The key fob now works from an impressive distance. The extended arial cable was put up the windscreen upright. Very simple amd very effective.
landrover key fobs have always been anoying as you need to be right close to the car before it will work. No more.
Happy days Bow downt
Post #606398 3rd Mar 2017 1:55pm
