Home > Puma (Tdci) > cruise control for Puma
Page 6 of 6 <123456
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Any idea where (on dash?) to put central unit of cruise control ?
Thanks www.newfoundland.gr
Post #387739 12th Jan 2015 5:27pm
dgardel
Italy
Inside the facia at the Left (for you RHD, on the right for me LHD) of the fuses door
Cleaned the internal surface from the dust and used 3M professional biadhesive tape. Job done!!!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #387757 12th Jan 2015 6:31pm
TJ101
Ditto, Same here, all tucked up out the way under the dash, to the left of the pedals California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #387763 12th Jan 2015 6:43pm
pouf
Thank you Dan !!
P.s. I am also normal Mr. Green (LHD) driver
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  www.newfoundland.gr
Post #387780 12th Jan 2015 7:21pm
dgardel
Italy
Embarassed Embarassed From Athen.
Sorry mate, but in this forums there are a lot of Defender all running with the steering wheel on the WRONG side....
Whistle Whistle Whistle
Rolling with laughter Rolling with laughter Rolling with laughter
Bow down Bow down Bow down Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #387861 12th Jan 2015 10:49pm
MartinK
Just a wee add.
I've spent ages fitting the Nakatenanga kit over the last few days. Actually it is quite easy to fit, but the instructions are not at all easy to decipher! A decent set of instructions would have allowed me to do it in around 1.5 hours, but it took ages.
Having said that, the Naka kit seems VERY good. I only used it briefly so far, but I really like some of the features (like 2 "set" buttons so you can get the system to memorise 2 speeds, and immediately resume to one or the other).
If anyone buys the Naka kit (from Brendan I hope) I'm happy to PM my experiences to help with the install Thumbs Up
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #437080 11th Jul 2015 5:26pm
Pickles
Photos of installed unit/control unit/stalk etc would be good please.
Pickles.
Post #437154 11th Jul 2015 11:16pm
Alien
Australia
Pickles,
All going to plan I should have one from Mobile Centre fitted by the end of next weekend.
Hopefully you can see it at the end of the month in Ferntree Gully. Cheers,
Kyle.
Post #437346 13th Jul 2015 6:00am
Pickles
Very good Kyle,...I have that date in our diary.
How are you going with "entrants"?
Pickles.
Post #437349 13th Jul 2015 7:03am
Alien
Australia
Cruise all fitted.
The rain washed our work out so I got given 2/3 night off with access to the big workshop it was to good an opportunity to waste.
Numbers are slowly building for our social day but feel free to post and ask who's going.
If I start a new thread it'll get merged fairly quickly into the existing thread. Cheers,
Kyle.
Post #437490 13th Jul 2015 5:59pm
Alien
Australia
Thought I'd through a picture up of my switch fitted to the left of the column.
I fitted it where the headlamp switch mounts.
I slipped a old nut over the cruise switch shaft and found a wire grommet that fitted around the nut and into the cowl.
With this set up the switch is solid as it's onto the steel panel not the plastic.
The headlamp switch is now on the right side of the column.
There was already a cut out in the steel panel and the cowling had a grove where it needed to be drilled/cut out.
The only issue was the contacts where close to the steel so I did a small modification, as you do.
I had a look and found the power contact, spring and ball where all reversible in the internal block.
All that was needed was a file of 2 little knobs on the internal block.
This allowed the lever to be reversed so when mounted the contacts are now facing up.
The lever works in revere now while the symbol is the correct way around so still looks factory.
Instead of pushing the switch down the column to turn the head lights on I pull it up. Cheers,
Kyle.
Post #450464 30th Aug 2015 5:08am
Not sure now on the other kits but these guys were able to offer quite a pick and mix approach to various options and potential upgrades:
http://www.conrad-anderson.co.uk/products/...se-control
Choice of 3 different stalks:
GC3 - Stalk Command Module
Functions:
On/Off (Push away)
Set/Increase Speed (Push up)
Resume/Decrease Speed (Push down)
Coast (Push towards you)
GC4 - Stalk Command Module with 2 Preset Memories
Functions:
On/Off (Push away)
2 Memory functions
GC5 - Stalk Command Module with 3 Preset Memories
Functions:
On/Off
Set/Increase Speed
Coast
3 Memory Presets.
Base kit on offer at £296.45 inc VAT
Post #495063 22nd Jan 2016 10:23am
Morepower
New Zealand
Does anybody know (or better still have a photo, showing the location of the speedo plug and which wire is the signal)... Just I've seen quite alot of installs which spice into the loom... This is all fine and well whilst everything is working perfectly...
I'm just looking at making a proper piggy back loom, So the cruise is completely separate...
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #496047 25th Jan 2016 8:50am
Page 6 of 6 <123456
