![]() | Home > In Car Electronics > Tow bar electrics - trailer light with no trailer |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
It is normal and correct that the trailer repeater flashes once (with the first flash of the indicators) if there is no trailer connected. If there is a trailer, it will continue to flash with the indicators.
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
If it just flashes once when you indicate then that's normal, it is doing a check to see if there's a trailer fitted or not. Just hope that it will keep flashing when there's a trailer attached
| dashed Member Since: 12 Jan 2015 Location: Manchester Posts: 29
Many thanks for the super quick reply! is this the same with both after market and orginal LR?
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
its a throw back from the times when dash warning lights were filament bulbs instead of led, its a bulb check
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
Does it even with no electrics connected
1988 90 Td5 NAS soft top
2015 D90 XS SW |
my dads tdi 110 does it with factory kit, as did my td5 before I changed to leds and wipac trailer relay
Thanks all! Have to admit I didn't notice it doing it without the electrics connected, but I've not driven a couple of hundred miles yet!
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
It won't do it if you have an RDX relay, only if a trailer is connected.
| NOODLES25 Member Since: 10 Dec 2014 Location: Wirral Posts: 46 |
My 90 does it with factory towbar,didn't realise why until now.
