Home > Maintenance & Modifications > Replacing a Td5 Alarm unit?
andy vash
Hi, I’m just about to replace the standard alarm on my Defender Td5.
I have asked around and apparently the best alarm to fit is a Toad Ai606T5 Thatcham alarm. The problem is when I unplug the Land Rover alarm I can no longer start the vehicle , I’m assuming theses an immobilizer circuit running through the devise
Can anyone advise in what I need to do in order to totally remove the Land Rover alarm, do I need to short some wires together to complete a circuit?
Thanks
Post #38266 16th Aug 2010 6:08pm
mse
Contact a professional alarm company.
First its not appropriate to discuss on an open forum
Second I would only fit a decent alarm that is thatchman and to keep the rating, by a professional installer.
third you cant just short some wires its a professional alarm fitted Mike
Post #38269 16th Aug 2010 6:12pm
Porny
Site Sponsor
Re: Replacing a Td5 Alarm unit?
Thanks
Bit more than shorting some wires together - but not hard to remove the immo function from a Td5.
In saying that, there is more than one way to do it depending how far you want to go.
Even professional alarm companies don't know how to do it... which often means you end up with 2 key/alam fobs on Defenders.
You can get a upgrade kit to make a standard LR alarm CAT 1 - which means you just keep the LR key fobs... you just need to ask the right people Wink
Feel free to PM me for more info if needed.
Ian
Post #38751 21st Aug 2010 4:54pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Sorry to sound cynical, and my sincere apologies if this causes offence......but 1st post here and asking about how to bypass the immobiliser on a TD5?
I'm not sure you'll get much luck with answers here fella. Mark
2011 110 XS DC
Stornoway Grey
Post #38755 21st Aug 2010 5:54pm
mse
Or should anyone help...especially with the rate of thefts. Mike
Post #38760 21st Aug 2010 6:05pm
roel
There are 2 ways of not needing the LR key fob anymore.
1. The TD5 can be programmed in a way it doesn't need the keyfob anymore or
2. Bell auto services can do something with your ECU that it doesn't look for anymore for ths As10 alarm ECU so no key fob neede either. Roel
2003 90 Td5 (2009-now)
Post #38869 22nd Aug 2010 8:30pm
