Home > Maintenance & Modifications > Prop Shafts, UJs protection
Page 2 of 2 <12
Only thing I've seen that comes close but wouldn't solve your particular issue:
Post #386588 8th Jan 2015 11:33pm
Cheshire110
No worries guys, seems I was just unlucky!
I'll just vaguely keep an eye on things down there and will clean it off a bit more. Cheers, David
Post #386598 8th Jan 2015 11:48pm
landy andy
Just wasn't sure if I'd been lucky, or maybe due to always running QT diff guards that have that sticky out bit under the flange had been secretly saving me.
Any thoughts?
Andy
Post #386615 9th Jan 2015 12:25am
Cheshire110
Supacat, what is that? It would at least stop anything working its way down the prop into the UJ / diff seal Cheers, David
Post #386618 9th Jan 2015 12:28am
David - it's a commercially available uj cover - although it just looks like a section of silicone hose with a reducer section in the middle finding the right dimensions might be quite a task.
The ones I saw were on EBay I think.
Post #386677 9th Jan 2015 11:24am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
MR_JAMES wrote:
Laughing They got the same idea I have. Think these would bend though... and scoup up dirt...
Post #386688 9th Jan 2015 12:17pm
zone30
A huge shrink sock would not unbalance the prop-shaft, if it exists of course...
Post #386689 9th Jan 2015 12:19pm
blackwolf wrote:
IIRC in Series One days there was an optional guard for this purpose.
MR_JAMES wrote:
Thank you, that's exactly the Series One part I had in mind.
It would actually be much easier to do now anyway since the front diff has the flat lower surface and the two unused threaded holes for the harmonic damper (as used on Discos etc but not Defenders). So a suitable flat plate bolted to the bottom of the diff extending under the flange would achieve the same effect.
Post #386726 9th Jan 2015 2:25pm
Happyoldgit
Yes I've had the same happen to me many moons ago. There were optional rubber gaiters for Series vehicles which covered the sliding joint, the instruction clearly stated the securing jubilees need to be set in opposition to each other to maintain balance. I'd seen the bolt on plates too. Anything fitted to the propshaft will need to need the balance issue addressed - those uj covers are a bit like tractor PTO guards..... Steve.
http://forums.lr4x4.com
Post #386750 9th Jan 2015 3:52pm
[quote="zone30"]
Thinking along similar lines maybe gaffer tape would work - although I think covering the uj might actually cause more issues than it solves?
Post #386803 9th Jan 2015 7:10pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
I have had this issue several times when fetching the hay in after baling.
The solution was cut a childs plastic football in half around its circumference, cut a hole at the top and slide it down the prop,
(split the sliding joint) the ball covers the uj and the nose of the diff. Bingo , no more knackered diff seals
Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #386881 9th Jan 2015 10:47pm
found this version also:
Post #387536 11th Jan 2015 8:59pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
here are some...
http://www.ebay.co.uk/itm/land-rover-serie...25a13fdfd3 1953 80"
1987 mini city e
2011 90"
Post #404252 3rd Mar 2015 9:47pm
Page 2 of 2 <12
