Home > Puma (Tdci) > Water on passenger side floor mats Defender Puma?
Page 2 of 3 <123>
OleDave
United Kingdom 2007 Defender 90 Puma 2.4 CSW Indus Silver
Hi tookaphotof thank for the contact, have sat in the vehicle with it chucking it down and driven it while it rains and there is no sign of any water coming from anywhere, doors, roof etc, leave it outside the house for a day or two and the passenger mat has water on it !! there is no doubt in my old mind that the water is coming in behind the dash from somewhere, screen seal, bulkhead seal or the hinge joints or another possible as some have said is through the blower, when I can muster up the enthusiasm and on a dry day I am going to lift the cubby tray and panel and have a look at the blower drain to see if its blocked, who knows it might be as simple as that? its a matter of checking one thing after another until I find the problem as the one thing I hate in any vehicle and which annoys the hell out of me is ingress of water.
Some problems can a nightmare to solve. One such problem was a 530 BMW I worked on where the floor mat on the nearside rear was suitable for ducks, the problem would not go away, eventually I found the cause it was a detached vapour seal behind the door card, even though it looked ok on a previous inspection there was one tiny area where the mastic had come away from the door body around the door catch, the resolve was a new vapour seal, clean the frame and reseal, job done!!!.
Many Thanks
Ole Dave
Post #380229 19th Dec 2014 11:24am
OleDave
Hi Jomara, Ah I see now, Hmmmm thats a thought ! that could be a good idea, where do you get them from? may I ask or are they widely available?
Regards
Ole Dave
Post #380259 19th Dec 2014 1:59pm
OleDave
Hi again Jomara, just found the snow shield on ebay, many thanks.
Ole Dave
Post #380260 19th Dec 2014 2:02pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi, sorry to spoil your fun but...
I had a Bearmach seal in my old TD5 for about 2 weeks when I had my screen replaced a few years ago. Bloody thing leaked like a sieve - I eventually got the screen refitted with genuine land rover seal (3x price) and that never leaked again.
Post #380264 19th Dec 2014 2:16pm
OleDave
Hi dnorrishill, oh hells bells dont say that my man!!! the LR seal was 5x the price, will just have to suck it and see what happens now? anyway by the looks of it I can discount the bulkhead seal as my Captain Tolley arrived this morning so I duly went out with my toast in one hand and the capatain tolley in the other as its dry for a change and applied it all along the bulkhead seal and waited, and waited, and waited but it didnt seep into any unknown cracks just sat there!! hmmm guess there are no tiny cracks then in that area so can maybe discount that thank goodness, one down and many more to go by the look of it.
Have looked this morning all along the inside of the screen seal and although grubby it looks dry but that dont mean squat really.
Will have a chat with National wind screens before hand in case they dont have any suitable sealer, it will give me a chance to source somat before the day arrives, pity I cannot use sikaflex on the seal as I used that on my caravan seals which they recommend, hells tooth that stuff is the dogs whatsits but its messy and a swine to apply and get off but seals as tight as a ducks butt when on.
Regards
Ole Dave
Post #380276 19th Dec 2014 3:25pm
K9F
Top Tip....A soft rag and white spirits will remove Sikaflex and give you an excellent finish. Do not use it on windscreen seal as if it ever has to come out fitting and sealing a new one will be a bain. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #380374 20th Dec 2014 12:44am
OleDave
Hi K9F no I would never use sikaflex on the screen although its did an excellent job on the caravan awning rails, I have another top tip for using sikaflex, I found that putting it in a bucket of warm water for half an hour helps in the application as if stone cold you cannot get it out of the tube!!
Rewgards
Ole Dave
Post #380400 20th Dec 2014 9:39am
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Hey Hoe my 6 month old Defender (now on 6000 miles) in Land Rover dealership in Newport to have leaks sorted
- passenger side I think the door seal is the culprit
- driver side the seal to the underside of the windscreen surround needs replacing
Whilst in there
- they are fitting genuine RAI (needed for me as I spend a lot of time on dirt tracks, constructing them for wind farms)
- asked them to look at the juddering in second gear (wont hold my breath)
They have loaned me a brand new 110 with only 9 miles on the clock and this does not kangaroo/judder the throttle pedal seems to be less responsive when you are slightly on the gas where mine is ever so sensitive.
I may push to have the throttle peddle sensor replaced to see if this improves things
Post #386401 8th Jan 2015 6:46pm
OleDave
Hi Iktank and all the guys, sorry to hear that your new defender is also leaking water, its annoying with a new vehicle and as usual while its in for repairs your without a vehicle! think I have found the problem with the water on the passenger side floor? last week I bought and fitted a snow cowl, since then it has rained quite a lot and believe this there is no water on the passenger floor!!!!! fingers crossed that the cowl is the resolve of the water problem, when the weather gets a bit better I am going to lift the centre cubby tray and remove the floor panel and have a look to see if the blower drain is blocked with rubbish which others on here have mentioned they can. If that does not cure the problem long term it looks like the next step will be the windscreen out, but at the moment all seems fine.
The door rubber on mine are by no means new and seem to fit where they touch but I do not have any leaks from that area, will possibly later in the spring or summer replace them all anyway as they tend to come off their location occasionally. Hope LR get your problem sorted soon.
Regards
Ole Dave
Post #386654 9th Jan 2015 8:46am
DaveGL
2007 Defender 90 Puma 2.4 XS CSW Cairns Blue
I have the same issue with water laying on top of both front footwell mats.
I have removed the internal trim from either side of the windscreen and it's wet in both bottom corners of the windscreen.
I have poured some captain tolleys in around the top of the screen rubber but am not convinced this will do it.
What do others recommend for this ingress point, new windscreen seal?
Thanks!
Post #386736 9th Jan 2015 2:59pm
OleDave
Hi Dave, if captain tolleys has not stopped it then sadly, and I think others will say the same, the only course of action would be a new seal, I can tell you how much a LR windscreen rubber is as I checked recently, they are £68. plus I was quoted £98 for a new screen and fitting, the rubber as mentioned was in addition to that price.
When the problem with mine started I did consider taking out the screen and fitting a new glass and rubber myself as I have done that before on another vehicle years ago but not a windscreen, what put me off doing it is if I crack the screen on refitting it or it leaks its my problem!!!! if National glass who quoted me crack it its down to them to get a replacment at their cost, tricky decision Eh!!.
Hope the above helps Dave, hope you solve the leak
Regards
Ole Dave
Post #386764 9th Jan 2015 5:07pm
DaveGL
Thanks Dave!
I will mull it over for a while. I can't imagine the Captain Tolley's will actually cure in the dampness behind the seal, but we'll see.
Post #386791 9th Jan 2015 6:33pm
Pickles
Hello from Aus.
There's nothing worse than a leaking windscreen.
I had a leaking screen in a previous car, & a panel beater friend of mine, he's bloody good at anything, a real "Mr Fix It", sorted the issue very quickly with a soft rubbery non hardening bituminous sort of stuff that he "inserted" with a gun, all along both sides of the outside of the screen,.. screen to body, & screen to glass.
This gooey type stuff obviously filled up all the "gaps",... result,...didn't have to take the screen out, or renew any w/screen seals/rubber etc, & it NEVER leaked again.
Pickles.
Post #386865 9th Jan 2015 10:27pm
DaveGL
Thanks pickles, can you send him over?!
Post #386889 9th Jan 2015 11:04pm
OleDave
Hi Dave and Guys, howz you Pickles? another thought Dave, after much discussion with the guys on here who have been a mine of info re my leak, some of the chaps who have had similar problems and have had the screen out mentioned that on removal a lot of dust/sludge had collected behind the seal on the inside.
Captain Tolleys in this case I doubt would work? it is good as I have used it myself as a precaution on the bulkhead seal as that could also be a possible, however, after applying Captain Tolleys around the bulkhed seal it just sat there!! the conclusion was there was nowhere for it to seep into.
My guess is if you can see the damp on the inside at screen edges then no doubt its finding its way through the seal, possibly any sludge deposits acting as a capillary for the water? It would be interesting Pickles if you knew the name of the sealer the Mr Fixit used? however in reality the best route is take the screen out and give the area a good scrub before refitting the glass along with a new seal.
Regards to both of you
Ole Dave
Post #386932 10th Jan 2015 9:46am
Page 2 of 3 <123>
