![]() | Home > Technical > Nolden / Speaker EVO2 headlamp comparison discussion |
I also think Nolden might come out on top tomorrow
I confirm everything ![]() ![]() ![]() Also my EVO had corrosion in the areas of contact between the case and the ring and the condensation issue. Another problem was the flickering effect just after the engine start up. true that disappear after a few seconds, but over the time could be cause of problems to the LED string. Personally I think that the Nolden outweigh the JWS EVO2. The evo 2 have a pattern that, with the hi-beam selected, illuminate more nearby the "nose" of the defender but Nolden "shoot" at a greater distance (imho, better HI-BEAM). but this image amplifies this effect and, in my opinion, does not reflect reality ![]() Click image to enlarge When "Low beamed" Nolden and EVO2 not show significant differences, may be JWS has a spot well illuminated very closer to the car but with a not well illuminated area just next . ![]() Click image to enlarge Last but not least I noticed that these effects (such as photo effect) are very sensitive to the adjustment of the headlights, are sufficient 2 or 3 degrees more or less of difference of inclination. May be related tho the sharper pattern of the LED headlamps Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Daniele, when you say that "Personally I think that the Nolden outweigh the JWS EVO2."...
I presume that this means that you have already tried them, yes? If correct, as you have the SVX front,I presume you have tested the EVO2 with front position light. Since the EVO2 with front position light also has integrated DRL, I would be interested to see pictures of this EVO2 with 1. only the DRL on, and 2. with the position lights on. In the last case I presume that the DRL turn off, and from pictures seen it seems that the DRL and the position light are one and the same (top half circle) LED unit. I guess that it probably means that with the lights off and DRL on, the entire half circle is lit up as DRL, and that with position lights on, only part of the same half circle stays on as position light. ???? By the way, I never saw a picture posted anywhere of how the Nolden position lights look when on. Think I never even saw a picture of the Nolden with position lights in the first place. I know a few Defenders here in Geneva with Nolden, but they all have the standard front, so with separate position light. Anybody has such pictures and can post? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Noticed the lights on the special editions
![]() ![]() Click image to enlarge |
There are some video demos of various LED headlights on here
http://www.headlightrevolution.com/LED_Headlights_s/1822.htm And some familiar photos... Of Eric's truck on this website Here is a comparison of jws evo vs jws evo 2 http://www.headlightrevolution.com/JWSPEAK...tion2b.htm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2709 ![]() ![]() |
Don't follow the logic here! You're implying that because they are fitted to the last Defenders they are the best??? Is that because they are fitted to a vehicle that doesn't rust? Is it fitted to a vehicle that is going out of production? Is fitted to a modern vehicle with a pants alarm system Is fitted to a vehicle with a dubious build quality? Or did LR just get a great group buy and found them at a mega cheap price. Just asking like ![]() ![]() ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Thats why I
![]() Speakers Rock ![]() |
I'll take your word for it. Can't see any LED lights appearing on my 110 in the near future
It's really curious how we take the parts with one or the other type of lights almost fighting ......
haa human nature ....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
My truck? On which website? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Eric .. here http://www.headlightrevolution.com/Nolden_...l-7led.htm
click on the small images in the gallery, bottom row, 2nd from right (you and Loius) |
![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Nice to see they asked
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
I know. It's amazing. Eric's rose-tinted glasses also seem to be preventing him from remembering actually getting his EVOs working properly in the first place. I remember this because I replied to his appeals for high-powered diodes at the time. http://www.defender2.net/forum/topic15899.html Pete |
