![]() | Home > Technical > Instaling rear tow hook |
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 ![]() ![]() ![]() |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Are we talking front tow eye?
Or rear tow bar? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Nothing bolts through the bumper bolts, bar the bumper,, You have "lashing eyes" bolted through the chassis rails,, but would not want to tow the vehicle with these Presume you meant a rear towbar ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Penguin, by tow hook do you mean the tow ball at rear of the vehicle for towing trailer/caravans.
If so the hardware is simple bolt onto rear cross member and onto the chassis. Electrics? Depends if you want 7 pin or 12/13 pin for towing modern caravans. If 7 pin then it is simple plug and play IIRC. 12/13 pin slightly more awkward Or do you mean recovery eyes to pull your vehicle out when it is stuck in the mud? Brendan |
Yes,, easy job, both the bar, and electrics,, allow 500 euros California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Front towing eye is fixed on mine through the bumper bolts
Same on my old discovery too!! Must just be mine then? ![]() Wanted, Forward Control Anything considered. |
Who is selling the 110? If a 4x4 dealership you might just get them to fit one as part of the deal. It certainly should not be a deal breaker. When we got Hazel's replacement 90 we just told the garage to fit one as part of the deal. Brendan |
It's indeed via a dealership, and we will for-sure try to get this in the deal ![]() ![]() In a time of chimpanzees, I was a penguin. |
OK you are buying a second hand 110, so if you are not insisting on everything being brand new, the dealership might have a second hand/take off tow bar equipment in their store somewhere.
Well worth asking. Good luck. Brendan |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Pics? Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
I went the jate ring route, through the chassis rails 110 adjustable tow bar with electrics fitted ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
