Home > Technical > my mrs 90 no drive !!!!!!!!!
defenderq
United Kingdom 2010 Defender 90 Puma 2.4 HT Loire Blue
Hello to all.....just bought my wife her first defender 2010 hardtop blue white roof. Had it just under a month and she loves it !!!! had a pajero few years back and that did everything very well but she prefers defender. Driving back on friday had a couple of clonks from drive just thought it was bit of backlash. Stop at some lights under m25 bang no drive, managed to get in a layby. No drive transfer box noisy, joined AA £350 and 6 hours later landy back on drive. It seems from posts 2010 defenders prone to link from gearbox to transfer box fails, has a warantee so fingers crossed be back on road soon. What with this and totally rusted solid windscreen wiper shafts my wives defender journy has been a little bumpy...... will let you know the outcome....... Very Happy
Post #385272 5th Jan 2015 8:30pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Yep, common problem although quite straight forward to repair, if your handy with the spanners!
Done one a few weeks ago, mine is next!!
Good luck in getting it sorted Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #385280 5th Jan 2015 8:50pm
defenderq
update
cheers....found local landy place that will do it ... guy bought it from will pay for repair but no transport.....£450 down and its still on me drive would have been easyer doing meself ..... parts £70 ...i suppose if its not just shaft the guy will cover it...bet it snows before we get it back....aaaahhhhhh
Post #385513 6th Jan 2015 5:31pm
ian series 1
Is it a tdci? Or td5,300tdi?
Just asking as all the parts for tdci amount to around £150 so make sure you have been quoted for correct parts.
But if it's td5 might just be input shaft?
Tdci have a different problem/set up, intermediate coupling shaft which fails! 80" 80" 86" 88" 90"
Post #385521 6th Jan 2015 5:52pm
defenderq
2.4 2010
its a 2010 2.4 tdci i think...found part numbers and found bits on ebay...im not paying for parts or labour just the transport. Looked at job and if it wasnt under warrantee would do it me self....its all kinda guesswork till they pull it apart, there did seem to be a small amount of rust at the bottom of the tunnell between gear box and transfer box. there was a small hole kinda semi circle (drain hole ? ) and rust seemed to be coming from there...Maybe thats cause landrover dont greace them..
Post #385537 6th Jan 2015 6:22pm
ian series 1
Don't recall any holes in that section of the box, but sounds like someone's been there before!
Maybe trying to spray some lube inside?
Only way to lube it is to pull it apart, maybe water has entered the hole and rusted the splined shaft?
Would be interesting to see it once it's out! 80" 80" 86" 88" 90"
Post #385539 6th Jan 2015 6:29pm
ian series 1
If you look back in the puma section on here you will find the post "another one with worn splines"
That was the one I done a few weeks ago, just so you know what sort of job it is,
Grease nipples are the way to go!! 80" 80" 86" 88" 90"
Post #385542 6th Jan 2015 6:33pm
defenderq
will take picture of hole it looks like meant to be there
but to be fair was in layby with aa mans torch so will have another look...greace nipple would be cool....and if they have any left over could put them in wiper stems !!!!!!!! will check puma post cheers Very Happy
Post #385543 6th Jan 2015 6:44pm
ian series 1
Ahhh the joys of owning a landrover!
"It does get better"
At least that's what I was told! Laughing 80" 80" 86" 88" 90"
Post #385548 6th Jan 2015 6:50pm
defenderq
good post and pics
just checked out puma post good pics and info....funny if these cars we cherish so much where chinease pit bikes you would be anoyed but fair doo... it was £125 quid off ebay but the whole think stinks really should be a free upgrade kit with greace nipples ....its pretty poor ... like my spelling !!!
Post #385551 6th Jan 2015 6:54pm
defenderq
im sure
when its all done ill be in love again ...but im £450 quid down 4 weeks into ownership ,just after christmas and mrs needs car for work she is a nurse whole point of "reliable Landy" she is now driving £600 quid matiz my daughter in law has had for two years no probs ... you could go off road in matiz just pick it up put it in your pocket walk accross field then get back in it...deep joy..landy does still look pretty on drive
Post #385555 6th Jan 2015 6:59pm
munch90
yes there is a small cut out in one end of the casing between main box and t/box as standard , only small about 3 - 4mm wide and about 8 -10mm long , just a small drain hole if i remember right its in gearbox end on the mating surface
Post #385573 6th Jan 2015 7:22pm
defenderq
that sounds
like the kiddy ..... think the rust is coming out of there ...when it lost drive there was no warning other than a couple of clonks then bang crunch ..no drive... maybe clutch gone too ?
Post #385579 6th Jan 2015 7:32pm
mk1collector
The high/low lever hasn't dropped into neutral has it? Sorry if it's a daft question.
Ray
Post #385583 6th Jan 2015 7:37pm
defenderq
not such a daft
question but no .....high dif lock nothing ...low dif lock nothing ...high / low nothing ... kept thinking migh be that ...wish it was .....makes a cool grinding noise if you lift clutch with every thing engaged
Post #385590 6th Jan 2015 7:49pm
