![]() | Home > In Car Electronics > Poor DAB and FM since DRL install :( |
NigelM Member Since: 20 Nov 2014 Location: South Posts: 114 ![]() ![]() |
I had terrible am reception when the headlights were on. Previous owner had installed HID's. The ballasts were bolted to the inside of the engine compartment - metal cased ballasts onto a metal bracket. I didn't move them, just insulated the ballasts from their bracket.
All reception issues instantly disappeared. |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
Unfortunately I've got nothing to insulate here. Just 2 plastic DRL modules with a positive and negative. 2008 Defender 110 XS SW - M57N2 / 8HP70X
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1322 ![]() ![]() ![]() |
You can make an inline supressor
Have a look here http://www.defender2.net/forum/topic26844....adio+choke |
jhnstap Member Since: 01 Apr 2013 Location: Bournemouth Posts: 73 ![]() ![]() ![]() |
I had similar when fitting the DLR form MobileCentre, went with Ferrite suppressors, seemed to help
http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0 I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine |
I fitted an inline suppressor on the ignition feed to the head unit. This has had no effect. Should it have been to the constant positive to the head unit instead or as well ? 2008 Defender 110 XS SW - M57N2 / 8HP70X
You have to fit the suppressor to the item causing the "noise" not to the stereo
In this case fit to the DRLs |
