![]() | Home > Td5 > R380 drain plug on a Defender TD5 |
Just use a half inch ratchet with extension. No socket needed
tpy Member Since: 27 Jan 2014 Location: paris Posts: 17 ![]() ![]() ![]() |
Thanks mk1collector.
I found out via a post on Landrovernet.com from the owner of a 2006 Kalahari 300tdi that my drain plug could be a 3/8inch square. That would match my impression of an almost 10mm square. So, no socket indeed, I just need to find a 3/8 ratchet! |
Sorry, yes 3/8 not 1/2 inch
kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55 ![]() ![]() |
you may find its a 8mm square as used on Renault sump plugs looks like a 3/8 drive square until you try and get a ratchet to fit it!!!!
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
They're 3/8" drive plugs.
