Home > Puma (Tdci) > Oil pump question
Page 1 of 6 123456>
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Oil pump question
Back at work today I had the joys of stripping down and removing a 61 plate transit engine,
Customer had said it had lost power over a 5 mile distance, he pulled over to check under the Bonnet, no issues so went to start it and it was seized solid!
I have now found out it was the oil pump failing!
Talking to a ford main dealer he said a lot of the 2.4s suffered with this and ford had come up with an improved pump!
Has this ever been a problem in the Defender before? Or did Landrover address this problem?
Or is it only a transit related problem?
Just got me thinking that's all.
Ian 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #385194 5th Jan 2015 7:09pm
munch90
mainly we find its the 2.2 having problems
don't think its so much the pump its self , more something to do with the chain drive from the crank down to pump
normally knackers turbo as well
Post #385196 5th Jan 2015 7:12pm
ian series 1
Thanks, so it's a Landrover problem too?
I was just wondering if there was ever a recall for this, or just a small few that were just unlucky! 80" 80" 86" 88" 90"
Post #385197 5th Jan 2015 7:16pm
munch90
not a recall as such done , but fords seem to now about it , but if you get problems within what ever the warrentry is ,then they will do it , think if your out of warrenrty its your problem
I think it will be a problem with any 2.2 guessing there all the same inside
not that common on the 2.4 , cant think of any of the top of my head
what is your one your doing 2.2 or 2.4 ?
Post #385198 5th Jan 2015 7:21pm
ian series 1
2.2, customer has gone away to find a good second hand engine!
It turns out the van has never been serviced from new!
No stamps in the book, oil was like water,
156000 miles! 80" 80" 86" 88" 90"
Post #385211 5th Jan 2015 7:39pm
munch90
He done well then
some are only lasting 20-30,000m
i think there has been 1 or 2 defender 2.2s on the forum with pump problems
another reason to stick with the 2.4 Thumbs Up
Post #385212 5th Jan 2015 7:41pm
ian series 1
On a happier note, I get to "squirrel" the old engine away under my bench, especially if he gets a "complete"replacement and not just a short block,
Spares for a few years! Razz
Many thanks for your info.
Post #385216 5th Jan 2015 7:52pm
vito115
Someone i know had his Transit 2.2 euro5 recalled for a modified oil pump
Post #385232 5th Jan 2015 8:15pm
GEllis
England 2013 Defender 110 Puma 2.2 USW Indus Silver
I have a 12plate 2.2tdci 90 with 62k miles, just had a whole new engine and turbo all under warranty with three months warranty left due to oil pump failure.
Post #385271 5th Jan 2015 9:26pm
ian series 1
Out of interest, anyone know if there are differences between 2.2 and 2.4 oil pump?
I was lead to believe that the blocks and internals were the same,
Only bore size was different? 80" 80" 86" 88" 90"
Post #385277 5th Jan 2015 9:40pm
munch90
I think only think the later 2.2 had a different oil pump drive chain tensioner or guide and it breaks , say not 100% on this
Post #385308 5th Jan 2015 10:45pm
Cuthbert
Is it the oil pump itself that fails? Is it sudden and catastrophic?
OR
Does it lose sufficiency (gradually or suddenly), pressure drops off and other engine components/bearings/top end/bottom end fail?
OR
Is it the chain drive from the crank to the pump that fails?
OR
Is it something else?
Having bought a new 2.2 I'm interested in learning more - are there tell tale signs or is it sudden death?
Post #385314 5th Jan 2015 10:58pm
munch90
Think its the drive chain , should be able to find out more tomorrow
sudden death , normally complete engine and turbo needed
Post #385323 5th Jan 2015 11:20pm
GEllis
Not sure what went, I will find out, but it was sudden. No warning, vehicle just stopped and the dash board warning lights lit up. Recovered to dealership new engine and turbo followed.
Post #385327 5th Jan 2015 11:27pm
Fifth Horseman
The oil pump is different on the 2.2 from the 2.4 and so far has had three different part numbers which could indicate that problems have been found in production - a similar thing happened with he oil pump on the 2.7TDv6 in the D3 (went through five revisions - see the disco3 forum).
Tensioner and chain are the same between the 2.4 and 2.2 though Confused
Post #385346 6th Jan 2015 12:02am
Page 1 of 6 123456>
