![]() | Home > Puma (Tdci) > New toy added |
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
dont forget to fit your bumper end caps
![]() 1968 1/32 scale Britains 109 Pick up. |
Yesssss
I'm building a small plate for fix it (the military bumper have 2 big holes closer the ends just where the normal one have the small holes for the plastic clips)... ![]() ![]() ![]() IID Pro MV License |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2151 ![]() ![]() ![]() |
Wow - now that will flatten a punto properly!
tee hee! ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
hi dg,
been studying the picture of the front of your defender, I see you have a hole in your bumper, buy where's the new toy ?? |
Yes, is the military bumper:
- 3 mm thickness (vs 1mm of the original) and double on the center where are placed the tow shaft holes - full boxed on the central section good for Fiat Punto ......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 ![]() ![]() ![]() |
Very nice dgardel. On another note how are the led lights? did you fit them yourself, easy to fit? I'm still saving for those lights
![]() ![]() ![]() '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
Yes I fit myself and it easy, only the retain ring need to make a little cut before install it. If you'll need i?ll give you all infos.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
is that not like mike tyson putting a horse shoe (cartoon style) in his boxing glove
![]() i mean i dented my house with a standard bumper (series 3 but same as defender) no joke i did. |
Definitely, I ll keep you in the loop. Cheers '08 LR Defender 110 '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
BarneyRubble Member Since: 08 Mar 2010 Location: Naphill Posts: 103 ![]() ![]() ![]() |
Hi Daniele,
Where did you get the bumper from and what was the part number? Barney D4 - 2016 Graphite, Montalcino Red Written Off - 2010 90 Hard Top, Stornoway Grey |
![]() ![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I micro sanded the retaining rings
