Home > In Car Electronics > Fitted! Double DIN Parrot Asteroid Smart. + now DAB
Page 5 of 7 <1234567>
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
does the tom tom apk have speed cameras?
Post #368458 31st Oct 2014 11:14am
Cheshire110
I *think* so, but you may have to subscribe or set it up in some way.
It does on iPhone, and I've seen on my smart that you can definitely pay for traffic etc. Cheers, David
Post #368466 31st Oct 2014 12:30pm
Cheshire110
Dension DAB addon
Fitted my Dension DAB addon today, with a powered aerial/splitter thingy from DabOnWheels.
Very happy with the results. It plugs into the USB on the Smart and gives each station as a .mp3 file as if you were browsing a USB full of music files, very clever. Only slight annoyance is a 15-20sec buffer at the start of each station when you switch to it.
Signal through the standard aerial (now amplified) is very good. I'd say nearly as good as our Range Rover but not done much testing yet. Perfect reception on a short journey I made before.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #384100 2nd Jan 2015 2:32am
Northernremedy
United Kingdom 2004 Defender 110 Td5 CSW Aintree Green
Nice!! If you don't mind me asking how did uou use the standard aerial? Do you not need a separate DAB AERIAL?
Post #384118 2nd Jan 2015 9:33am
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
There seem to be a few different powered DAB splitters that allow you to use your existing aerial.
Found this thread that might help;
http://www.defender2.net/forum/topic31762.html
I used one from Autoleads, bought from Amazon. From memory it cost about Ł30. The reception is great for DAB, better than a factory fitted unit I had in my Ford Galaxy.
Post #384121 2nd Jan 2015 10:15am
Cheshire110
yep, you got it.
This is the product that DAB on Wheels recommended-
http://www.dabonwheels.co.uk/High_performa...ctive.html
but its available on eBay for less than a 1/3 of the price, the exact same! Shocked Not sure what happened but id still recommend DAB on Wheels, theyre good for advice and some of their other products are better priced.
I bought this exact item, arrived very quickly and works like a dream...
http://www.ebay.co.uk/itm/Kinetic-DAA-7001...19e9b28ba2 Cheers, David
Post #384150 2nd Jan 2015 1:06pm
Cheshire110
this is the Dension DAB+U that i bought, for anyone interested:
http://www.amazon.co.uk/dp/B00HW1W37S/ref=...71_TE_item Cheers, David
Post #384151 2nd Jan 2015 1:07pm
Northernremedy
Cheers! Looks a lot easier than routing via alpine window
Post #384152 2nd Jan 2015 1:35pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Might be me, but seems like a huge gap underneath the vents? Embarassed
Post #384155 2nd Jan 2015 2:08pm
Cheshire110
yes there is! Big Cry
the double din facia doesn't come with the clock/vents bit so you have to cut that bit off the old facia. You then need to glue it to the new facia but I've never got round to glueing it in place to be honest!
i think id left it sticking out a bit when i took the picture too, its better now. Cheers, David
Post #384158 2nd Jan 2015 2:54pm
tookaphotoof
Thanks, will think it over again I guess.
Maybe I should just upgrade to a single din and skip the reverse camera / screen part...
Post #384350 2nd Jan 2015 11:46pm
Cheshire110
It's really not a difficult task, just one I never got around to doing yet... Cheers, David
Post #384366 3rd Jan 2015 12:15am
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
has anyone else tried fixing this volume control to Parrot
You can buy the control here
http://store.fusioncontrolcentre.com/index...duct_id=61
I am thinking it will fit neatly in the circular space in the extended fascia..
@Davidwhittaker
Any wiring adapters that I should buy to connect Parrot if I am replacing the stock Defender Audio?
Post #425037 20th May 2015 10:33am
Cheshire110
I bought one a while ago and it just plain didn't work. Don't know if I was doing something wrong or if it was broken, but I gave up anyway. Didn't find anywhere useful to put it and I got used to not having a knob, it's fine for me. Cheers, David
Post #425275 21st May 2015 9:13am
Ahmed
Bahrain 2015 Defender 90 Puma 2.2 SW Aintree Green
Hi Arsath,
Yes fitted and works great, here are some pics that i took during the install.
Used small screws to secure a square teflon piece from the front under the nob, and 4 small screws again to secure the controller to the teflon.
I don't have a dipper switch on my car, thats why i used that empty space Smile
Post #427133 29th May 2015 7:46pm
