Home > Maintenance & Modifications > rear middle door electric windows
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
has anyone do that?
any ideas? www.newfoundland.gr
Post #37892 11th Aug 2010 9:13am
Eduardo
pouf
I seen one some time ago in a TD5. they used a scrapped motor and mechanism from other TD5.
Works OK. Probably alsio you can use those system to transform manual to electric ones with more less the same results
Cheers Eduardo
Post #37915 11th Aug 2010 4:55pm
pouf
if i understand right, you take the mecanism of the front window and you transform it to the rear door.
brilliant idea Thumbs Up
thanks a lot eduardo!!!!! www.newfoundland.gr
Post #37926 11th Aug 2010 9:45pm
BigRuss
I did hear of a one off which rolled out off the line with fitted rear electric windows.
I can't see there being a space issue in the door for this, I would think the hardest part is going to be setting the stops up properly even over the wiring.
Post #37929 11th Aug 2010 10:15pm
Along time ago when god was a boy there used to be kits that had external motors ie a plastic box that piped over the handle spline nice Rolling with laughter
Post #37941 12th Aug 2010 4:56am
pouf
-only a weimaranerer could anwser that Laughing Laughing Laughing
-BigRuss, you have to be sure we will find a solution if there is any Mr. Green www.newfoundland.gr
Post #37949 12th Aug 2010 7:46am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
It's something I've thought of as a solution to stopping the bloody rear windows from shacking open on rough tracks.
Interesting to hear how you get on. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #37963 12th Aug 2010 10:17am
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
I saw an advertisement in one of my French magazines for such a kit. I'll have a look for it. 130 crew cab
98 V8 Disco
Post #38191 15th Aug 2010 9:06pm
parktag
Here's a link for the kit i'm thinking of fitting.
http://www.spal.it/default.php?t=site&pgid=44
They have two kits available, Universal model 140euros or original model 300euros. 130 crew cab
98 V8 Disco
Post #38378 17th Aug 2010 6:41pm
