Home > Td5 > Turbocharger wastegate short circuit CURRENT
df1
i read my fault codes today and this appeared up,
Turbocharger wastegate short circuit current 01-05
I get a bit of blue smoke and misfire today, first time ever, I stopped the engine, restarted and it was fine.
The fault seems funny to me as it is not electronically controlled wastegate..
Could this be related to the misfire and blue smoke incident or purely coincidental.
Should I just start with the usual suspects, loom oil etc ?
Thing is it has run perfectly clear since, only lasted about 20 seconds.
Post #383701 31st Dec 2014 6:42pm
munch90
Guessing the code could be for the electric vaccum control valve that controls vacuum to the wastegate diaphragm, what it means sorry not a clue !
Post #383708 31st Dec 2014 7:22pm
df1
I thought the diaphragm was just controlled by a pipe from the induction pipe just before the inter cooler ?
Post #383727 31st Dec 2014 8:50pm
munch90
Not really had much to do with td5 , but looks like they have something like this
eBay Item No. 321076065397
Post #383732 31st Dec 2014 9:05pm
df1
Think they are disco only.
Post #383740 31st Dec 2014 9:28pm
roel
AFAIK td5 disco's wastegates are ECU controlled but Defenders are not. Roel
2003 90 Td5 (2009-now)
Post #383741 31st Dec 2014 9:29pm
^^^^ +1
Discoveries are ECu controlled, defenders are mechanical, so there's no "error" code that can occur from them.
Post #383772 31st Dec 2014 11:32pm
df1
Is it possible that the error code is generated because of over or under boost pressure in manifold then ?
Maybe the pressure sensor in inlet manifold faulty ?
Post #383807 1st Jan 2015 8:47am
roel
Can you clear the fault and see if it comes back? That's what I do with my D3. If it comes back quickly I will look further otherwise it's just one off the things.
I think over boost will have it's own faultcode, under boost I don't know. The td5 will go to limp mode if to high manifold pressure is measured. Roel
Post #383813 1st Jan 2015 9:50am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
If it is over boost, it will log as "turbo charger over boost"
From what it seems, there might be a wiring issue.
Clear the faults first and then see if it comes up again. The defender has migrated, leaving the owner behind.
Post #384497 3rd Jan 2015 4:08pm
df1
Cleared the fault 2 days ago and hasn't come back.
Still a bit puzzled how I had the blue smoke then just clear. Hasn't reappeared either.
Beginning to think it's something with the injector loom.
Post #384611 3rd Jan 2015 8:59pm
roel
Is there oil in the red connector at the ecu? Roel
Post #384818 4th Jan 2015 3:38pm
df1
Red plug completely clear.
Post #385388 6th Jan 2015 9:15am
df1
Post #385389 6th Jan 2015 9:15am
roel
Then you probably not have a injector oil loom problem. Roel
Post #385486 6th Jan 2015 4:30pm
