Home > Maintenance & Modifications > Britpart h/d springs and cellular shocks
williamthedog
Hi all,
Thinking of fitting the above to my pick up.
Anyone fitted these, i know its britpart, but heard the springs are quite good.
What are your thoughts or other recommendations.
Its carrying 250 kgs up on standard everyday ,including rack and tent.
Thanks in advance
Post #383663 31st Dec 2014 4:42pm
NigelM
Just put Koni's on mine. Fantastic difference to shot standard ones. Very pleased with them. Put lighter springs on as well, but they will be no good for you with 250kg in the back.
Post #383664 31st Dec 2014 4:51pm
Mdm
They will be soft and leaning in under 12 months
Better t spend a few more quid and buy something that will last and give a good ride
Post #383706 31st Dec 2014 7:16pm
williamthedog
ok any recomended set ups ?
What about genuine landrover h/d springs ?
Post #383715 31st Dec 2014 7:53pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
We fitted Britpart HD springs on my 90 for our Australia trip, paired up with koni heavy track shocks, travelling around 15k miles. All fine and no sagging on our return to the UK and still going strong.
The combination performed brilliantly on all terrains, including long runs on Tarmac, gravel with heavy corrugations, soft and hard sand. This was with a heavy load (see our blog for details, link below). Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #383724 31st Dec 2014 8:38pm
roel
The springs are OK. I cannot comment on the shocks as I don't use them.
I have 225lbs/inch in the front and 275 lbs/inch in the back. And I still bottom out in hard landings. Shocked
I am most off the time not bottoming out when charging up a hill. I had that problem with the standard springs.
I got these 2nd hand and cheap, my final setup will be determent when my build is almost finished.
Edited because wrong springrate. Roel
2003 90 Td5 (2009-now)
Post #383739 31st Dec 2014 9:25pm
williamthedog
Thanks,
I knew that the britpart springs were better than their usual gear i just wanted to hear off someone who had actually used them. Thumbs Up
Post #383750 31st Dec 2014 10:03pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Ive got HD Britparts on mine +2 s and very happy with them
Post #384474 3rd Jan 2015 1:42pm
Phatcat
United Kingdom 2002 Defender 90 Td5 CSW Java Black
Got a set of HD britpart standard height springs for sale if they are any good to you. Had them on about 6 months, but took them off as I lowered my truck.
Post #384872 4th Jan 2015 6:23pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
I've had britpart h/d +2 springs on a 90 for nearly 7 years, it still sits level. I can't fault them for the money. I'd try to have a spin in one with them fitted first though, they give a very harsh ride.
regards
Post #384901 4th Jan 2015 7:26pm
Bows
Just adding to my previous, my experiences are with a relatively empty 90, your 250kg may well improve the ride in comparison to mine.
Post #384903 4th Jan 2015 7:28pm
williamthedog
Thanks for the advice everyone, have ordered the springs.
Going to think about what shocks to go with them Thumbs Up
Post #384928 4th Jan 2015 8:17pm
