![]() | Home > Puma (Tdci) > How sluggish does your EGR clean sound in the cold |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Dont know mate
Mines turned off & blanked ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Sounds the same as any other time. The EGR is disabled by the Alive remap but it still performs the self clean cycle on shut down to stop the valve from being coked closed.
It's freezing here too and I have standard LR engine tune, EGR sounds the same as any other time, 5 gentle chukas at same pace as always, no screeching or scratching sound, that is so for years now after I changed to exclusively using BP Ultimate diesel. :thumbs up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
I don't know what it sounds like????
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Chuka Chuka Chuka!!!
![]() Wanted, Forward Control Anything considered. |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 ![]() ![]() ![]() |
Mine is fine when the car has run for 10 minutes, however on a cold day it sounds like it doesn't move properly.
Jonno |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
If it sounds odd then it's probably a sign that it's going downhill.
![]() ![]() I'm yet to know an EGR that is any good for any period of time. |
On a positive note if there can ever be one as far as EGR valves go, mine has been sounding ill when cold for at least two years and hasn't totally failed yet.....
Jonno |
