![]() | Home > Technical > running out of fuel |
dealers do have a priming pump for filter changing etc,you should have two keys,the crap these dealers think up is un believable regarding missing items 2.4 90 XS
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
had a road side recovery guy empty my fuel filter to check for water in the fuel, he just fill'd it up with diesal and i had no problems starting after, it says in the hand book that its not good to run out of fuel but if you do you need to put at least 5 Lt in the tank to get it restarted, which tells me that it should start, and you get 2 keys with 2 remote locking fob's in the uk.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
There have been some earlier posts on this. Including one where AndrewS made his own priming tool.
But as i mentioned then and as DCH mentions, there is no need to bother, it does seem on all occasions i have come across so far to self prime eg: fill it with fuel and turn it over. Mike |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Sat on the Pont-Aven ferry returning from a trip to Morocco. I had to replace the fuel filter on the 130. It would not re-start when the new (filled with diesel) filter was fitted. I had to prime the system as described in the thread posted in the past using the home made tool. So glad I had it with me.
I have replaced filters in the past and never had to use the priming tool, the cars simply start, cough and splutter but keep running and all is OK. TF I had it with me. 130's have feeling's as well you know ![]() |
2 fobs was resolved ![]() |
Sounds like a gangster's grass! "I believe Bobby Crockfoot shot Jimmy 2 Fobs in the alley behind The Dog and Duck, he's now looking skyward counting traffic from under the M25!" Sorry 'Mad Moment' there! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1862 ![]() ![]() ![]() |
I had the same sort of fault, changed the filter but didn't fill it up
![]() I used some 10mm POLYURETHANE (soft and pliable) compressed air hose and a lift pump for a 200tdi - worked a treat. The polyurethane pipe is the soft type and it wont damage the seals if you're careful Ickle |
