Home > Technical > question about NAS rear step/tow
martyp1970
United Kingdom 2006 Defender 110 Td5 XS CSW Blenheim Silver
http://www.ebay.co.uk/itm/NAS-Rear-Step-La...TQ:GB:1123
this is the NAS rear step
My question is once fitted are they a capable of towing if fitted with toe eye.
Post #382876 29th Dec 2014 2:07am
Venomator
Do you mean eye or ball Marty... Question
Either way, the answer will be yes, when properly fitted... Thumbs Up
Although there may be mounting height issues depending on what you plan to tow... Whistle
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #382901 29th Dec 2014 9:42am
JAY BOY
Wales
Marty
There are 9 large bolts that hold the bumper on and 2x 20mm stay bars that go back to the chassis.
If its and original NAS im sure it can tow full load.
Thumbs Up
Post #382916 29th Dec 2014 10:21am
martyp1970
Yeah the eye/ball,
already got a pretty big heavy duty tow bar fitted with double electrics,
but I was thinking on replacing it with an aesthetically better looking NAS rear ,
so not really towing but you never know ,
so just wanted to know will it tow or is it just a show boat !
cheers
Post #382918 29th Dec 2014 10:23am
martyp1970
Re: ^ ^ ^
ok mate, cheers
Post #382919 29th Dec 2014 10:25am
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
only thing is, thats not a genuine landrover NAS rear step...
Post #383144 29th Dec 2014 8:32pm
TJ101
Correct, non gen, like most on ebay, and can not see the chassis stays in the pictures, ?
The Step/tow bars make the ball a fair height, and would not like to fit a drop plate and then tow to the Defender full capability and certainly not without the stays
Much as i would like a rear step/tow bar, my trailers are all too low a hitch for one California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #383153 29th Dec 2014 8:48pm
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
If you do want one, try and go for genuine as they will be up to towing or if not, at least from a good supplier. They vary in quality quite a bit. Regards
Dennis.
Post #389889 18th Jan 2015 6:16pm
I just about get away with it on lowest neigh with my 8' Ifor but larger trailers you wouldn't.
Post #389905 18th Jan 2015 6:48pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
It's not an original NAS bumper.
The NAS has a slot for a class 3 receiver hitch, and the 2 arms that extend down and bolt to the frame. Looks like that bumper bolts only to the rear crossmember. Nice thing with the original NAS is you can slide in a tow ball, pintle, etc.I actually dragged some large douglas fir trees around my property after they were felled with a chain attached to a cleat into the hitch.
Post #389987 18th Jan 2015 9:38pm
ehagerty
Based on the research I did recently, the USA 'NAS step' had trailer hitch, while the current NAS-like 'rear step' has a flat panel with bolt holes. Both genuine LR have the arms that bolt to the frame, one way or another, whereas many of the less expensive aftermarket ones omit the arms.
Post #389994 18th Jan 2015 9:48pm
