![]() | Home > Td5 > Middle Front Seat |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Isn't that bolt just for the seat belt mount?
| Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431
Don't think so as it seems to hold the seat down ?
| mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142
I remember it being a steward to remove but didn't use a special tool.
Sorted, Halford is your friend !
Did indeed hold the seat belt and the seat in place. Socket set from the bottom and one of these babies up top and tadaa ! Sorted Cheers. Dunk Click image to enlarge |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
your right it the bolt at the end of the screw driver blade had to remove my middle front seat torx head
| ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223
Took my middle seat out recently. 2005 90 van style. To put a cubby box in.
3 bolts each side, 1 front (easy) two at rear. Yes, the rear bolts hold both seat and seat belt mountings, for middle seat - and the buckles for the other 2 seats - so these bolts and brackets all have to be put back! For safety reasons I guess at the rear: One bolt is into a welded nut underneath and can only be accessed by open ended spanner as the seat frame prevented ring spanner from access. On one of mine I had to angle grind it off, which of course ain't real good when you realise you have to put it all back together again for the seat belts. The other bolt is into a conventional nut but locktite'd and yes has a posidrive head. So all in all Land Rover really don't want these essential safety bolts coming adrift ... In hindsight I'd think twice, then think again, about ripping out a perfectly good seat for a cubby box. There is a lot of fiddling around to do to make safe and good afterwards, I should have let sleeping seats lie ... Brought the 90 home from Switzerland ... |
