|  | Home > Technical > fitting a spare with RR offset ? |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Vague post....what wheels do you have fitted would be the obvious question? If they are 16" boosts I would delete this post to save embarrassment perhaps? The rolling radius of the spare must be as close to the wheel it is replacing, offset is not as important as long as it doesn't foul as a get you home only option..
  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  29th Dec 2014 9:05am |
| martyp1970 Member Since: 21 Oct 2014 Location: Cramlington Posts: 40      | Sorry no embarrassment here,
 im running 20" evoque ( style 6 I think ) original alloys, with hub converters with hunter 4wheel alignment. I still have a 16" boost as a 5th spare on the back , I have bought a single 20" for a spare but will it fit onto the oe spare wheel carrier ,with being different offset !!! so if it wont fit as I said any ideas on something that will fit the rr alloy. cheers | ||
|  29th Dec 2014 9:16am |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | Rear spare wheel carriers are not expensive, and come up for sale on here from time to time. Consider buying a carrier and getting the bolts adjusted to match the rre spare
 Can't be much more than an hours measuring and welding | ||
|  29th Dec 2014 9:20am |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4804      | You could fit a carrier off a td5 discovery, wheel will bolt straight in without adapters   2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton | ||
|  29th Dec 2014 9:30am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | I am a little confused myself, we are talking stud pattern, offset or both? I would suggest if both remove the studs off your original standard carrier have a reinforcing plate welded onto the face and then perhaps drill and refit the studs exactly where you need them.
 Offset can often be adjusted by the adjustment spacer fitted to the original carrier studs to move it away from your wiper arm if required.   Click image to enlarge **Edit** Grafty's idea is better than mine. A lot less labour intensive.....    If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 29th Dec 2014 9:34am. Edited 2 times in total | ||
|  29th Dec 2014 9:31am |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4804      | The disco carrier bolts directly on to a defender rear door    2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton | ||
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Stud pattern.....is it not the same? If you go through life with your head in the sand....all people will see is an ar5e!!
|  29th Dec 2014 9:37am |
 cheers guys for replys, what year of discovery carrier do I need. | ||
|  29th Dec 2014 9:38am |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4804      | Anything in the lr range from 1998 on has the same pcd apart from the defender (I think) Any td5 disco should do it    2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton | ||
|  29th Dec 2014 9:44am |
 The td5 disco has the smaller stud pattern in line with the rest of the lr range 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton | ||
|  29th Dec 2014 9:47am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      |   Learn something new everyday. Thanks Grafty.  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  29th Dec 2014 9:57am |
| martyp1970 Member Since: 21 Oct 2014 Location: Cramlington Posts: 40      | Thanks again guys   | ||
|  29th Dec 2014 9:59am |
 No problem  2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton | ||
|  29th Dec 2014 10:00am |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127      | Hi
 Im running on Discovery 2 18" alloys on my defender (soon to be removed as i hate the hub adaptors!) I recently fitted a spare wheel carrier, it had an adaptor fitted on the spare too, so it would fit, but then i had issues in the length of the wheel carrier bolts, all in all it was a bit of a headache having to shorten the studs on the new carrier which i was not too happy about doing! I am doing away with them soon as if you need to do any work to hubs etc you have to remove adaptors too, bit like taking 2 wheels off all the time.......simply cant be doing with it   Still going with 18s but with Defender stud pattern! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. | ||
|  29th Dec 2014 6:40pm |
| Posting Rules
