Home > In Car Electronics > Bad Vibes from Subwoofer + No Bluetooth
Wheel
Morning Gents,
I hope you all had a good Xmas ?
I took delivery of my new 90XS exactly a week ago and have now covered just over 500 happy miles
BUT......
I have a couple of "concerns" with the radio.
I had the audio upgrade which incs the Subwoofer but it seems to vibrate a lot despite turning the sub setting down to 1 or 0 and also lowering the bass to 2 or 3.
I'm hopefully (optimistically) going to have a look today as things have been a tad busy here although i do have to try and sort out a non working boiler which was Ho Ho Ho fun over Xmas first
My other "concern" is the bluetooth works making or receiving calls but the mic doesn't and so i can hear the other person talking but they can't hear me.
I was thinking its probaly not connected to the head unit which i was expecting popped out with two 2 pronged radio removal tools except it doesn't seem to have the holes. Is the surround covering them and how does this come off if indeed this is the problem, again, does anyone have any suggestions please ??
I am a little disappointed that a £30k motor has such niggles and despite the obvious "its a LR" and "character" comments heard in the past i don't think that its on.
Thanks,
Mark
Post #382894 29th Dec 2014 9:23am
CatherineF
Personally I wouldn't mess around and try and fix yourself if the car is new. As frustrating as it will be get it back into the dealer as soon as possible.
Post #382897 29th Dec 2014 9:33am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Mark
I had the same issue when I got my silver 110, turned out the microphone hadn't been plugged into the head unit properly after a bit of messing about I decided to leave it to the dealer to sort out.
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #382965 29th Dec 2014 12:29pm
Laurie
This should cure it.....
Post #382976 29th Dec 2014 1:12pm
Pickles
Have a look at your subwoofer. There is a piece of plastic inside the bottom of the subwoofer that may not have been removed as it should've been. If you feel along the bottom edge of the S.W., you may feel a bit of plastic sheet. Unpeel it & your "vibration" will largely disappear.
Pickles.
Post #383186 29th Dec 2014 10:13pm
Wheel
Thanks everyone for the advice (and Beach Boys clip) and just to say that i've arranged to pop into to a dealers tomorrow morning as i agree i shouldn't have to mess about with it and/or potentially damage or scratch something to see, as suspected if it is the mic not plugged in to the head unit or loose, or more embarrassingly that i've been doing something wrong which may very well be the case as i'm not 14 and so don't do technology very well or that i am now officailly old and don't read a manual very well (or at all/much) either.
I'll also have a look at the sub tomorrow to see if its the sticky paper as Pickles suggests before i go as i've been busy with the now working (although frigged but needing a new directional valve) boiler today and i can at least live with a vibrating sub but a freezing cold house, now thats another story !!.
Whilst at the dealers i may also ask if the noisy wiper motor/linkage is normal or am i expecting too much from a £30k vehicle ??
Apart from these few issues i love being back in a Defender (from a Disco 2) again and hopefully the stack of new bits scattered around the house and garage will start to get fitted.
I fetted the Overfinch wheels on Friday and am thinking they were a good choice.
Thanks once again all,
Mark
Post #383456 30th Dec 2014 8:36pm
CatherineF
We need wheel pics Wheel Rolling with laughter
Post #383460 30th Dec 2014 8:38pm
Pickles
Good, make sure you check for that bit of plastic on the inside edge of the subwoofer.
I already had mine booked into the Dealer's to be fixed when I was told of the "bit of plastic", I think by a member of this forum! Subsequently I peeled it off & SW worked fine,..well as well as it can, given the boundaries of the system, & the Defender interior.
Pickles.
Post #383490 30th Dec 2014 10:04pm
glpinxit
The mic not plugged in properly seems common - mine had it too. (The radio bezel levers off and then things are obvious - easiest after taking off the removable face-plate.) Cheers, Guy.
Post #383811 1st Jan 2015 9:48am
Wheel
Yes it appears that the man on the line doing that particular job isn't, and worse still, the Q.C. man isn't doing his job of checking either !!!!
Anyway, it was connected and i'm pleased to say it now works as it should.
The noisy wipers need further investigation so its booked in for 1 - 2 days next Thurs (8th) when they'll also check the rear panel which looks like it caught the rr x member when the body was lowered onto the chassis.
The steering wheel is out of centre but they wouldn't check the tracking (and i'm kicking myself) as i'd fitted my Overfinch wheels which are "non std" so its on with the boosts before Thurs despite my arguments that the wheels wouldn't alter the tracking or steering wheel alignment, or would they ??
I don't know if its me or as i get older i'm less tolerant or expect more but why are things never simple ??
Post #383829 1st Jan 2015 10:40am
barbel jim
Its not you, the majority of people try to do the bear minimum, have the 'that will do' attitude. its your fault for buying something that they cant afford. Whistle
and no as long as the wheels are straight and fitted correctly, it should not alter the tracking, but it gives them an excuse to pass the buck !!! Modern day attitude again
Post #383856 1st Jan 2015 12:27pm
Jim, trouble is those 'slapdash' types are the ones that usually get the jobs due to having a big mouth.
Sometimes company overheads also cause it by pushing timescales come what may.
Post #383859 1st Jan 2015 12:34pm
Wheel
Despite people not doing what they're supposed to for whatever reasons there should be processes in place to make sure it firstly gets built correctly, then it should be checked and finally if there is a problem a containment put in place while the process is corrected.
Its really just basic stuff to address and poor show on LR who obviously have a problem judging by the number of people who have had the same issue which got fixed by the dealer under warranty which LR pay them "handsomely" for.
I think LR are really negligent as all warranty data is fed back to them and they obviously haven't done anything about it which means adds to their cost, and who ultimately pays for this ??
Yep, us, the customer !!!!
I feel an e mail coming on to someone at LR soon
If not already, i fear i'm turning into a grumpy old man !!
Post #383874 1st Jan 2015 1:25pm
barbel jim
Join our club http://www.defender2.net/forum/topic5612.h...grumpy+man
They have systems, which have failed at all levels. the final one would be the PDI that the dealer obviously meticulously undertook Rolling Eyes
Post #383880 1st Jan 2015 1:42pm
Wheel
Yes you're right, and there in lies another problem as i bought it 200 miles away as no one more local could beat or even match the price and although not in so many words they really didn't wanna deal with it as i wasn't one of their customers !!
I'm hoping modern Defender ownership is going to settle down soon !!
Post #383895 1st Jan 2015 2:44pm
