![]() | Home > Technical > Speaker Indicators HELP!!! |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Whip 'em off dry them on the radiator overnight and then get some decent sealer and seal them up. Replace with units that are at least IP 67 rated. JW Speakers are supposed to be synonamous with quality and rated to IP 67 anyway? Had a similar experience with headlights. Speak to Tim I am sure you will get a satisfactory resolution. Use a sealant that can be removed to get you home. If you go through life with your head in the sand....all people will see is an ar5e!!
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
Cheers k9f, Lights now sat on the radiator... However, Any one local to Gairloch got a spare set of brake / tail lights I could borrow if these don't dry out?... I now have no rear lights at all and I'm not holding out much hope of these springing back into life any time soon.
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I'm not that local in Glasgow but if you are down this way you can have a full set of OEM lenses with my compliments.
Brian. |
Tim,
I do like your signature.......deperate times etc.....Could you not get your mate to do a round trip to Inverness to try and get his heater working and go with him? Wrap up warm and you may kill two birds with one stone perhaps? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
It may yet come to that.... Let's see if they spring back into life... Where in Bournemouth are you as I work for Crescent Racing WSBK Team and if you interested I can give you a guided tour of the bikes...
Tim,
I am not a million miles away from Crescents Shop in Charminster (who are Yamaha dealers now are they not?).... About 5 minutes away near the Broadway Pub. Great offer and one I would willingly accept thank you. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| All times are GMT |
