Home > Maintenance & Modifications > -14 to -20 have you topped up your antifreeze?
Page 2 of 2 <12
munch90
from new
Post #382331 27th Dec 2014 4:09pm
shaggydog
Quote:
Had the bonnet up on her today and there is a Land Rover Label about genuine Land Rover Anti Freeze and Do Not Drain.
I have the same referring to swivel grease, I know it is genuine because thats what I put in, but I would doubt it if it wasn't mine and just walked up to it.
Unless you know yourself suspect it not to be and then only use genuine. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #382333 27th Dec 2014 4:23pm
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
So what's the deal of mixing different coolants, or rather: how can I tell what type of coolant is in mine? Defender 130 HCPU Td5 MY2000
Post #382563 28th Dec 2014 10:18am
munch90
red with red only ( most common now days easy to get )
green or blue can be mixed (not so common nowdays , better to flush out and change to red )
that's the basic rule
but they are some odd antifreezes , really best advice is to change / flush / anti freeze if you don't know whats in it then keep it the same
Post #382564 28th Dec 2014 10:22am
ericvv
Why topping anything up, unless you have been loosing coolant?
The Puma has antifreeze in the cooling system from new, and according to LR maintenance schedule needs to be flushed and replaced by new only after 200.000 km.
I don't think over the years antifreeze looses its main function, i.e. to protect against frost, no?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #382566 28th Dec 2014 10:27am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Is your coolant red or blue ? If it is blue it is glycol based and must be topped up with a similar glycol based anti freeze and changed every two years, If it is red it is OAT anti freeze and must be topped up with red anti freeze this usually has a life of five years before it needs changing. 2005 Td5 90 XS
Steve
Post #382567 28th Dec 2014 10:29am
munch90
Eric
it should be done on millage or years old which ever comes first really not just amount of miles its done
you change it to get rid of any cr@p in it , rust dust etc
most cars will use a very small amount of coolant and if someone just tops up with water your losing the strength of anti freeze
advice , buy a tester
general rule change every 5 yrs on average mileage car
and if you really want to get excited about it , don't use tap water , use CLEAN rain water
some say just use tap water , some say distilled water , some say rain water . there are fors and against and not sure anyone knows 100% which is best
but water with less additives and impurities should be better
Post #382568 28th Dec 2014 10:37am
RoadForce
Thanks for the info re red and green/blue coolants, appreciate it and learned something new today! Defender 130 HCPU Td5 MY2000
Post #382582 28th Dec 2014 11:31am
Page 2 of 2 <12
