![]() | Home > Puma (Tdci) > Bonnet springs open |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I would clean it up and grease both the catch, and the bonnet pin,
Had this happen on a td5 at work, just lack of lube was fine afterwards! ![]() Also check alignment of bonnet pin and catch by removing the grille and checking. Check cable for any slack and adjust as required. Ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
vodonos Member Since: 13 Jan 2013 Location: CERKNICA LAKE Posts: 29 ![]() ![]() ![]() |
regulate bonet hinges! BOŠTJAN
SLOVENIA Cerknica lake 90 td5 2000 110 2,2 2012 |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
Need to do this with ours. Was looking at it the other day and thought it all looked a bit dry. |
Yep, one of the first things i done when i got mine,
when i went to look at it, i noticed how badly the bonnet opened and shut! Ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
