![]() | Home > Maintenance & Modifications > -14 to -20 have you topped up your antifreeze? |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762
Our car had a 48K Mile Main Dealer service last spring, would new antifreeze have been put in it?
I notice it had an engine flush according to the invoice. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Doctored an answer for you......
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
LOL!
Someone reads my posts at Christmas - YAY! |
| Andrew james Member Since: 02 Jan 2013 Location: Awliscombe Posts: 88
I am about to go to in Norway, so I am good for minus 50
Bring it on! |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Thanks for the reminder- I always check level but rarely consistency!
Should be ok but needs a top up so will top up with coolant Self confessed mileage hunter |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
This Pov.spec,ftw. 2006, 110,TD5. |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
Just buy a cheapy tester and check it. Too much is just as bad as not enough
Don't think the usual testers can test oat anti-freeze,dunno?? Pov.spec,ftw. 2006, 110,TD5.
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
What problems does too much anti freeze cause ? Checked mine and Mrs Sparts the other day hers was ok to about -32 mine was about -40 !!! 2005 Td5 90 XS
Steve |
Yep they do
Too much anti-freeze actually freezes and can cause overheating problems believe it or not. Your specs are fine |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Run Evans Waterless Coolant in my vehicles good to -40.
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
55% mix good for -50C
Had the bonnet up on her today and there is a Land Rover Label about genuine Land Rover Anti Freeze and Do Not Drain.
Is this something that would have been on it from the factory or does it sound like it's been applied at a service? |
