![]() | Home > Technical > amber engine warning light |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
Hi Folks,
On a 110 td4, 2008, lhd, 50k. Amber engine check light came on last night on the way back from hols ![]() ![]() Thanks ![]() |
In my view Scangauge is about the most practical and cheapest option for the reading and resetting of fault codes. You can also transfer it between vehicles unlike Blackbox Solutions faultcode reader which I hasten to add is quite a bit more expensive. If you go through life with your head in the sand....all people will see is an ar5e!!
Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 19th Aug 2010 9:57pm. Edited 1 time in total |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
From my experience with the ScanGaugeII it will only show and let you clear some ECM faults and only when the check engine lamp has come on. At which point you can clear what is causing it. I found at other times it wouldn't report any fault codes in the ECM even though there were. 110 2.4TDCi
110 300Tdi ![]() LROCV ::: AULRO.com |
ickle's amber MIL light is on.....Going to a dealer and asking him to investigate the cause and reset the fault can cost you the same as a Scangauge.....As an alternative means and as a possible 'get you home tool' the first time a Scangauge is used to clear a fault it will in principle pay for itself I'd say. ![]() Treat every day as if it is your last....one day you will be right!! |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
Get it sorted under warranty?
Don't disagree with that, just pointing out it will only clear what it can and not anything else. Mine got me 250km stopping every so often to clear the MIL because of a blown IC hose and the turbo boost pressure dropping. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
It obviously worked for you then as a 'get you home tool for over 150 miles?' I wished I had had a Scangauge when my MIL light came on due to my EGR Valve. I still reckon for the cost it's worth it....Justin!
'Justin case you need it!' ![]() As Canonball suggested Ickle could go to the dealer under warranty or even call LR Assist if he didn't wish to leave home! ![]() Treat every day as if it is your last....one day you will be right!! |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
I cant say i like scanguage - im coming round to the idea of Hawkeye, they seem to be really progressing it now.
Just realising maybe i should have bought that than the Sony handycam ![]() |
Thanks folks,
I've only recently bought the car (please dont suggest taking it back, I wouldn't trust the trader I bought it from to check tyre pressures... ![]() I've checked all connections and they seem fine, although will the light stay illuminated even if there is no fault now? Does anyone know if there is any sort of tuning 'box' that will give diagnosis / clear faults? ![]() |
If it's an EGR valve fault that clears the MIL light will go out after three driving cycles! As already stated Scangauge is probably your cheapest option if you wish to 'manage' and reset faults! If you go through life with your head in the sand....all people will see is an ar5e!!
Dear All,
K9F - took your advice, bought the Scangauge I thought it was worth a try until I can afford a BAS scanner / tune! Anyway it worked a treat, thanks. ![]() MK - I think you were right, code was P1103 'MAF higher than expected but within range' the barb that holds the connector on is missing (ham fisted filter change I guess) so a loose connection could be the cause of the higher reading I suppose. Again many thanks ![]() Ickle |
Ickle,
I am slightly jealous as I haven't got a Scangauge yet! I am hoping with it being my birthday in the next few weeks and with a few hints the size of atom bombs my exhaust fund will stay intact! Or I will have to buy it myself! I spoke to Glynparry who has one and he said it would be worth the money spent the first time it was needed! Your feedback has strengthened my belief it is a useful and cost effective tool! Thank you! Glyn I believe has his down by the difflock lever, I would probably buy the mirror mount and stick it up there! Glad you have had sucess with it! ![]() Treat every day as if it is your last....one day you will be right!! |
Well,
Thanks to Ickle's feedback (which was the decider) I have imparted with my hard-earned and finally purchased a Scangauge. I await delivery with mounting excitement, I paid extra and bought the blendmount kit to mount it adjacent to the mirror. I still feel that if used just once it will justify the outlay...We shall see! Thanks Ickle! ![]() Treat every day as if it is your last....one day you will be right!! |
Second fault code cleared today (although it was a EGR so would have probably gone away on its own after 3 cycles) but I reckon I'm now in profit with the scangauge rather than taking it to a main stealer.
Does anyone know if the gallons on the scangauge are US or imperial as its programmed in dollars? ![]() |
