![]() | Home > Maintenance & Modifications > Anyone done a cat back system on 2.2 Puma |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
You can go completely straight through if you wanted but of course now you need the CAT present.
Alive do a CAT back system I think, you can get sooprts cats too but they are seriously pricey. |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2277 ![]() ![]() |
I'm confused
![]() I have a slightly better performance with both boxes off and won't be touching the DPF . |
So it's DPF instead of a CAT then?
Custom
Yeh mate probs the same thing but the cats were all easyily taken off midway along the exhaust . There's no way your gona get through emotions with straight through on the 2.2 . Even if taken off its then gonna haf to go to BAS to have the ECU jiggered about wi . A big hastle when you could be better to have it have BAS wave his majic wand on it easy . |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
IMHO, mucking around with the exhaust system on a Puma is not going to provide much, if any power gain.
However, I'd be interested to see a before & after dyno figure, stock exhaust against cat / middle muffler removed? Pickles. |
