Home > Maintenance & Modifications > Battery dead but very warm- what do i do?
Page 5 of 6 <123456>
munch90
no no black stays in the centre move red to other hole
left hole 10a fused
mid hole com ,black lead
right hole volts , ohms , milli amps
Post #381026 22nd Dec 2014 5:37pm
Venomator
Yes, of course, sorry just looked at the dial without the cables plugged in... Embarassed  Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #381027 22nd Dec 2014 5:41pm
shaggydog
Ok were getting somewhere.
At first connection there was a spark and it read 0.35 this then dropped down to 0.06-0.05.
I turned on my rear work light to get a comparison and it shot up to 5.55 but then dropped back down to 0.05 and stayed steady with everything off.
However, if I left everything disconnected and then turned on the light to drain any residual and then reconnected there was a spark and it shot back to 0.35 then dropped back to 0.05 - normal or something up? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #381028 22nd Dec 2014 5:42pm
Rickydodah
As Munch says the Red lead needs to go in the left hand 10A hole, if by chance it's drawing a lot of amps then you'll possible fry the multimeter otherwise. You may just get a more accurate reading if you connect meter between the positive terminal and lead, just be very careful not to induce a short, though it's unlikely to be much different. Thumbs Up I started with nothing and still have most of it left!
Post #381029 22nd Dec 2014 5:45pm
munch90
0.35 so 1/3 of a amp and then drops more , sounds ok (if your reading it right Rolling with laughter )
I take it your work light is not led and 55-60w bulb then it should be roughly the 5.5 amp reading you got ok again
sometimes you get a bit of a jump to begin with then its what it settles to that matters
sometimes its handy to have a couple of spare fuses for inside the meter as its easy to blow then (we have all done it Whistle ) normally use the small glass radio style fuses
Post #381030 22nd Dec 2014 5:47pm
Rickydodah
0.35amp is 4.2 watt, so not a lot, was the interior light on at the time? The 5.55 draw is okay if there's around a 60watt bulb in the lamp Thumbs Up I started with nothing and still have most of it left!
Post #381032 22nd Dec 2014 5:51pm
shaggydog
0.35 sounds fine to me (it didn't say syntax error so I assume so!)
Work light is a H3 Filament Bulb so no its non Led Thumbs Up
Everything else apart from the clock and tracker was off (including interior lights) Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381033 22nd Dec 2014 5:53pm
shaggydog
Ok so when everything is off it seems it is in fact all off.
So, does this put the failure of the old battery solely down to the battery itself?
In which case new battery has solved all the issues and we are now sorted Thumbs Up
Or does it mean we have now eliminated one thing off the list and now have another thing to look at, in which case what is it and how can I check it?
Also I owe lots of people lots of beers Bow down Bow down Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381035 22nd Dec 2014 6:00pm
munch90
don't temp fate with words like "has solved all the issues"
but yes seems it should be right Rolling with laughter
sorry if I talked you into buying a mutlimeter , but seen it lots of times battery replaced for no reason when something else was wrong , I prefer to know its right when it goes out
Post #381038 22nd Dec 2014 6:05pm
Rickydodah
The only other thing I can think of is going back to the alternator, you could try testing the resistance of the coils and the wiring, if the diode fails then it wil draw current back from the battery with the engine off. I have come across this before but never as an intermittent fault. Just a thought, fingers crossed. Confused I started with nothing and still have most of it left!
Post #381041 22nd Dec 2014 6:10pm
shaggydog
Censored your right I walked straight into that one didn't I Big Cry Rolling with laughter
Still, more to learn next time something happens. Thumbs Up
The old battery, as I still have it on charge, if I leave it on charge overnight then unplug it and measure the voltage, then leave it all day and then re test it will that determine the old battery to be usable as a spare or dead? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381043 22nd Dec 2014 6:14pm
munch90
don't think ive ever seen alternator intermittent fault either , also if the alternator fails this way sometimes in the dark you can see the battery light on the dash glowing faintly even when all off and locked etc
Post #381044 22nd Dec 2014 6:14pm
shaggydog
Not at all, I have been meaning to buy one for a long time and who doesn't love buying new tools Very Happy
I'm not sure I have coils as its a diesel Confused But could stand corrected! How would I test that?
Battery light goes out after a few seconds and then stays firmly extinguished so take that as a good sign Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381050 22nd Dec 2014 6:22pm
dorsetsmith
Battery light goes out after a few seconds and then stays firmly extinguished so take that as a good sign DC ALT is working Thumbs Up
Post #381075 22nd Dec 2014 7:26pm
munch90
What i ment was sometimes if the alternator is faulty in a certain way then the dash battery light can glow faintly even when engine not running , ign off and you can only see it at night in the dark its that faint
Post #381084 22nd Dec 2014 7:38pm
