Home > Maintenance & Modifications > Devon 4x4 D44 Transmission Guard
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
I had a go at fitting my D44 transmission guard at the weekend.
Was prepared for the transfer box oil to fall out when replacing the bolts with the supplied studs but when it came to it, I couldn't get the new studs into the transfer box as the handbrake backplate is too close.
Only tried one bolt (the highest one) so just put it back in and topped the oil up again.
Has anyone worked out how to do this without removing the handbrake (and I assume rear prop shaft)? MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #37509 2nd Aug 2010 2:26pm
jst
try calling Simon/Lis/Jake and asking them if the handbrake needs to come off to allow fixing.
yes the rear prop does need to come off if the handbrake is coming off. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #37525 2nd Aug 2010 5:45pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Re: Devon 4x4 D44 Transmission Guard
You need to shorten the bolts unfortunately. Either that or take the handbrake drum off. I'm going to fit an X-brake so it should be less of a problem. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #38064 13th Aug 2010 7:57pm
Mad Cow
I thought they looked longer than the standard bolt when it came out but my attention was rather taken up by trying to catch the oil leaking out Mr. Green
Think I'll go down that route as it's got to be easier than unbolting everything.
I was also thinking about an X-Brake but not just yet as In the last month I've had to shell out for my new wheels and tyres, a 24,000 mile service and the insurance renewal Shocked
Next month it's the tax, insurance and a new set of tyres for the BMW Sad
And that still leaves the engine rebuild on the CCM to do... it never ends Rolling Eyes MAD COW
Project90
Post #38098 14th Aug 2010 12:15pm
mse
I wouldnt worry about the x-brake anyway - never understood the obsession Mike
Post #38100 14th Aug 2010 12:34pm
Mad Cow
Only reason I had is that they don't hang down as far as the standard hand brake, not that relevant on most Defenders but the transfer box and brake on Pumas does sit lower (hence the decision to get the transmission guard).
Oh yes they don't fill up with mud either, not that that has particularly caused me any grief before. Having to clean the brake out every now and then at least means you check on the state of the shoes periodically. MAD COW
Project90
Post #38106 14th Aug 2010 5:10pm
mse
I hear a few people comment on filling up with mud - never had that problem, but the solution (in advance) on the discovery and the v8 was to remove the drum and drill 2 small holes in it, that allows the crud to drain.
Series land rovers had them early on and it works a treat...never had an issue and never thus had to clean one! Mike
Post #38113 14th Aug 2010 7:23pm
x-isle
Sorry to dig up an old thread, but I'll be fitting one of these in a few days.
How much do the new rear bolts need to be trimmed, I'd rather do this ready to fit than remove one and then cut to size whilst the oil empties.
Thanks Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #393684 29th Jan 2015 4:39pm
jwhat
Ireland 2008 Defender 110 Puma 2.4 DCPU Keswick Green
I'm glad you brought this up x-isle, mine just arrived in the post this morning Very Happy Tdci 110 DC
Post #393686 29th Jan 2015 4:44pm
x-isle
Ha ha, if we don't get an answer, do your's and let me know! Rolling with laughter Craig Rogers
2007 Puma 110 XS
Post #393690 29th Jan 2015 4:48pm
Isn't bolting something to the transfer box just loading those small points with all the forces the guard is going to encounter?
Post #393989 30th Jan 2015 11:20am
x-isle
Not really as it's bolted front and back so the load would be spread and certainly no more that it would if it got clouted with a big rock. Craig Rogers
2007 Puma 110 XS
Post #393991 30th Jan 2015 11:25am
OK - I thought the point of a guard would be to stop it getting any clout at all!
Wouldn't something like this from Safari Equip be better - I think it hangs off the chassis so gets the relatively delicate bits completely out of harms way:
Post #394033 30th Jan 2015 1:21pm
x-isle
Saw the SE one but decided against it due to the foot print of it which could give other clearance issues. The d44 one is more of a slider when going over areas with less clearance rather than to bash the crap out of it, such as dragging over the centre bank of deep ruts.
Although the transmission is lower, it's not crazy low and I've never caught it on anything, but for £60 it's peice of mind. Craig Rogers
2007 Puma 110 XS
Post #394044 30th Jan 2015 2:09pm
