![]() | Home > Puma (Tdci) > Speed sensor connector 2.4tdci |
Difficult to gauge without seeing the connector. Here are a couple of the 'usual suspects' that may be worthy of a phonecall perhaps? Dingocroft would be your best shot maybe?
http://www.dingocroft.co.uk/index.html http://www.vehicle-wiring-products.eu/ Good luck. ![]() Treat every day as if it is your last....one day you will be right!! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6699 ![]() ![]() ![]() |
I think I'm right that this has not changed from a Td5, so you want an Econoseal 3 pin plug.
You can get these for a few quid on ebay: http://www.ebay.co.uk/itm/3-Way-Female-Eco...1027871140 Same connector is used for the rear side/brake lights. Edited for stupidity - it's 3 pin ![]() ![]() ![]() ![]() Last edited by Martin on 21st Dec 2014 6:32pm. Edited 1 time in total |
More expensive than Martin's E-Bay link but here's a couple on the Dingocroft page if that is what you're after.....
![]() Handy link to their shop Martin thank you. ![]() http://www.dingocroft.co.uk/acatalog/Electrical_Miscellany.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Its a 3 pin econo seal!! Lots of people sell the Durite ones. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
What a
